Getting any IR remote to work with the RockPro64 ?
Hello.
I'm running libreelec on my RockPro64. I'm currently controlling it using yatse on my phone but I would like to use my amp IR remote.
I plugged an IR receiver module on the appropriate socket on the board, I set up kodi to work with my amp remote (using the instructions from librelec wiki) but the remote doesn't work.
It seems that there is no IR driver loaded.
LibreELEC:~ # ir-keytable
/sys/class/rc/: No such file or directory
No devices found
The receiver module is a 38KHz TSOP4838, which works perfectly on my Raspberry Pi3's GPIO with the same remote.
Is it possible to get IR-keytable to work on the board ?
Any help would be hugely appreciated !
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,070 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 917 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,927 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 863 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,650 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,724 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,162 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,453 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,182 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,762 05-16-2022, 02:34 AM
Last Post: dukla2000
