PCIe for network // Networkanalyzer
I'm pretty new with the ROCKPro64.
I want to build a lowcost Networkanalyzer for PLC networks. For this reason i want be able to use different desktop adapters.
My Plan is to install Ubuntu on the ROCKPro64 and plug in my Network Adapter on the PCIe.
But im not shure if this will work.
Does any one have some experience with uising the PCIe on the ROCKPro for Ethernet?
Thx in advance Q
(05-07-2019, 05:28 AM)Questioneer Wrote: Hi,
Thx in advance Q
ayufan has the experience on porting 10Gbps Ethernet card in Rockpro64, you can approach him at PINE64 wiki (ROCK64 channel, http://pine64.xyz then /join #rock64).
  Compatible PCIe Sata Controller spacebricker 1 1,579 02-06-2023, 10:03 AM
Last Post: diizzy
  PCIe bifurcation support (on RK3399) Arn 1 1,347 11-28-2022, 05:12 PM
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,522 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 5,019 02-17-2021, 11:35 AM
Last Post: dml-pc
  Nvidia GPU on PCIe User 18962 4 4,871 12-22-2020, 02:54 PM
Last Post: amiraeva
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 2,924 10-20-2020, 12:22 PM
Last Post: xmixahlx
  RockPro64 pcie Gpu Davidos 8 15,293 07-14-2020, 05:11 PM
Last Post: ProDigit
  PCIe failure odhinnhrafn 11 12,345 03-16-2020, 08:39 AM
Last Post: odhinnhrafn
Question Can we add PCIE hub 1 to many pcie card seaurchin 1 3,116 11-25-2019, 11:08 AM
  Tested PCIe cards and output kram0000 5 6,189 10-24-2019, 01:17 PM
Last Post: xalius
