Boot Ubuntu in CLI mode
Hey all,
Using the image here: http://wiki.pine64.org/index.php/Pine_A6....2C_Pine64
Works fine and all, but I don't need the GUI. How can I uninstall/remove the GUI OR just set it to boot directly to console?
sudo apt-get remove whatever-desktop-environment
reboot
sudo apt-get autoremove
sudo apt-get clean
Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(04-23-2016, 04:30 PM)utdrmac Wrote: Works fine and all, but I don't need the GUI. How can I uninstall/remove the GUI OR just set it to boot directly to console?
Why do you install an image with GUI when you need no GUI?
Can you point me to an Ubuntu image on the Pine wiki that has no GUI? I'm looking at the wiki downloads page again, and they all have a GUI pre-installed and pre-setup to boot directly to GUI.
You find my images in the development forum. No idea about the wiki.
(04-24-2016, 12:43 PM)longsleep Wrote: You find my images in the development forum. No idea about the wiki.
Found this thread, http://forum.pine64.org/showthread.php?tid=376, which lead me to this URL: https://www.stdin.xyz/downloads/people/l...es/ubuntu/
How do I identify which has GUI and which doesn't?
If you read the first post in this thread carefully, everything is noted there! There also is an Arch one, but if you like to stick with Ubuntu Xenial, just use the links you already found...
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
  Pine 1 will no longer boot (bricked) dstallmo 0 3,057 06-22-2023, 12:22 PM
Last Post: dstallmo
  Ubuntu server 20.04 request phi0x 2 10,499 12-30-2020, 08:02 PM
Last Post: phi0x
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 5,188 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 6,608 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 4,874 03-23-2019, 04:06 AM
Last Post: ktaragorn
  Resize /Boot mmcblk0p1 on SD? chadc 7 18,038 08-24-2018, 01:23 PM
Last Post: goathunter
  SPI on ubuntu IlyaM 4 14,008 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 13,653 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 16,802 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 895,742 01-31-2018, 11:58 AM
Last Post: Luke
