PCI-E Card failure?
Hey,
like how I ask in my previous post : https://forum.pine64.org/showthread.php?tid=7125 - I have connected the RP64 to an molex +12 Volt cable of my 600W ATX PSU - Its working without any pci-e card, booting up etc as expected.
If I test the voltage, my half working diagnostic tool say its arriving 13-14 Volt ... (is this normal? not 12v??) - I cant check the current (amp) but how I understand there should be enough amps, in the internet somebodys say its can be 12A depending on how many devices connected, so I have no other devices on that 600W PSU.
I try just with ayufans image : stretch-openmediavault-rockpro64-0.7.14-1081-armhf.img.xz
The SATA PCI-E Card which I bought:
  • Chipset: ASMedia1061 x 4
  • Ports: 8 SATA 6GB/s Ports
  • Compliant with PCI-E Specification V2.0 and backward compatible with PCI-E 1.X
  • Supports Native Command Queuing (NCQ)
  • Compatible with SATA 6G, 3G and 1.5G Hard drives
  • Compliant with PCI-E Specification v2.0 and backward compatible with PCI-E v1.x
That chipset, I saw was patched to the kernel which ayufan is using, I double checked in his source-code to find, and I did.
On the board, all the LED´s working normal, heatsinks of both cards are getting hot and the LAN-Port LED´s blinking as normal.
If I connect a HDMI cable, I get a signal, but the screen is blank/black (no cursor) - with and without connected card
Has anyone a hint how I can debug with a verbose boot to see errors or booting sequence on the hdmi signal?
Its possible that the PCI-E Card is not get enough power? I have a extender cable for PCI-E x4 (20cm) - ( If I connect it with that extender the RED/WHITE LED´s are not turning on or turning off quickly, without that extender the LED´s working normal. )
I saw several times on PCI-E GPU extender cables that is separatly powered with a normal DC-Jack plug. I have at office someof this mining pci-e x1 usb extender, but Im afraid its not provide enough bandwith for GIGABIT storage function.
[url=https://github.com/ayufan-rock64/linux-build/releases/download/0.7.14/stretch-openmediavault-rockpro64-0.7.14-1081-armhf.img.xz][/url]
(03-10-2019, 03:21 AM)smx Wrote: Hey,
I think there are different problems with the rockpro64 itself. See the posts under the linux section.
In my case my sata controller overheats (over 80°C), so it's not warm to the touch. Other users are reporting similar issues as well.
My guess is this is a hardware problem on the rockpro64 itself by not conforming 100% to the PCIe standard. But this is just a guess...
  AW-CM256SM wifi card mtek 4 2,363 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 908 09-24-2023, 04:40 AM
Last Post: JPT223
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,917 04-01-2022, 11:25 AM
Last Post: ashleymills
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,384 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Rockpro64 Sata Card kills itself jerry110 33 44,434 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 2,986 09-15-2021, 12:46 PM
Last Post: corax
  Industrial memory card m.ekstrom 1 2,440 03-23-2021, 05:55 AM
Last Post: barray
  Multiport Gigabit Card? jerry110 24 29,183 02-26-2021, 03:54 PM
Last Post: kuleszdl
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 5,017 02-17-2021, 11:35 AM
Last Post: dml-pc
  Won't boot with SATA card rjzak 4 5,769 01-09-2021, 05:56 PM
Last Post: kuleszdl
