Attaching a physical button to the ROCK64
Hi All,
I have downloaded the package that allows Python and GPIO interaction: https://github.com/mrfixit2001/Rock64-R64.GPIO
I have a button wired to the Ground pin and the pin 18 (https://www.cnx-software.com/wp-content/uploads/2017/08/Rock64-Pi-2-Bus-Pinout.png)
[/url]
so it looks like I am getting errors with my [url=https://pastebin.com/QpP1wgKH]script
(https://pastebin.com/QpP1wgKH).
errors appear after I ctrl-c in terminal, the two errors are:
Error: Unable to get GPIO value
You must setup() the GPIO channel (BCM 18) first
does anyone know what I am doing wrong?
take a look at this repo. it's a clone with some changes.
https://github.com/Matei-Ciobotaru/Rock64-R64.GPIO
another thing is you could use GPIO.BOARD instead of GPIO.BCM and maybe for test use value 18 instead of button.
  Are HW design files available for ROCK64? irenek 3 4,768 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,064 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 623 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,219 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,741 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,520 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,616 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,513 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,037 09-28-2021, 03:07 PM
Last Post: TRS-80
