Rock64 is unreliable after 3 years of service - power problem?
Greetings all,
I have a Rock64 that I was using to self-host some services (namely Nextcloud).
It was powered on 24/7 for the best part of 3 years. It was connected by my router by ethernet. The only other connection was an external hard drive - the HDD had its own power supply so wouldn't have a high draw from the R64.
Around a year and a half into service, the USB 3.0 port that had the HDD connected stopped working. No matter, I just plugged it into one of the USB 2.0 ports and didn't experience any loss in performance.
Now it seems the whole unit is suffering from something. The ethernet connection shows on my router and I can ping the box, but as soon as I try SSH I am disconnected. I can begin a HTTP request but Apache fails with an internal server error message. When I power it on and view the console output on a monitor, I can login using a keyboard and nothing seems amiss in the OS (Armbian).
That said, if I connect anything to USB after the unit is powered on, it immediately reboots.
Something isn't right here. I suspect power related, but I'm not sure. These problems came all at once.
Would appreciate any help or suggestions.
Thanks, RTG.
there will be no peace when they release the geese
my homepage
  Are HW design files available for ROCK64? irenek 3 4,780 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,069 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 624 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,232 01-15-2023, 10:36 AM
Last Post: ds00
  power connector type please AlexS 4 4,649 01-11-2023, 07:00 AM
Last Post: dmitrymyadzelets
  rock64 totally brick dakobg 2 1,749 11-07-2022, 05:45 PM
Last Post: olivercfc
  Alternative power supply ju0n 0 1,031 09-06-2022, 02:46 AM
Last Post: ju0n
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,532 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,629 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,538 03-04-2022, 06:56 AM
Last Post: killor
