rock64 totally brick
I do not have any idea what happen
I have several rock64 but one of them look like is brick!!!
I think the problem is with spi u-boot (or something else?!)
I try with different sd-carts different images including erase and flash u-boot-spi
Also I try to boot with shorting pins 25+23 or 25+21 and release after 2 -3 seconds after power is plugged .. this not help as well
I open a ticket to pine64 support .. they totally reject me .. short answer was .. check in the forum this is software issue they will help
At power-on all 3 lights are on + yellow on ethernet port
serial uart show .. nothing just from time to time no senses symbols (and yes I'm sure I use/connect correctly work with all other rock64 )
My quick question's
1. any idea
2. is there a way to try somehow to reflash rock64 ?! (look like I cannot do that for SPI only)
I think the problem can be something else not in spi .. also power adapter is ok for sure
I do not want to RIP this rock64 in the garbage since the situation with the chips is still terrible and will be waste of chips Smile   but if I do not have other options .. Sad
Disconnect all connections except power and serial console.
(If there is a connection to the USB-Port, disconnect that as well.)
1)  Disable SPI (shorting pins 25+23 or 25+21). (shorting pins 25+23 or 25+21)
2)  If eMMC is installed, disable it with a jumper pin.
In this state, write an image that has been confirmed to boot to the SD-CARD and boot.
(There is no need to remove the SPI jumper during the boot process.)
If you get a readable message on the serial console, you may be able to recover.
If, unfortunately, you get nothing at all from the serial console,
Try pressing the reset button several times, and the situation may change.
If there is no change in the situation after several tries, there is little hope of recovery.
(09-02-2022, 05:18 PM)dakobg Wrote: Hi,
My quick question's
1. any idea
Did you ever get a solution to this?  I have a rock64 that behaves identically to what you're describing.  Seems totally dead and if I try to boot with just microSD and serial (and 23+25 jumpered) I can occasionally get a symbol on the serial port but nothing more
  DeskPi case alternative for ROCK64 v1k699 2 13,475 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,737 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,628 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,469 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,541 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,099 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 22,042 01-15-2023, 10:36 AM
Last Post: ds00
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,148 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 8,125 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 28,818 03-04-2022, 06:56 AM
Last Post: killor
