Does any Os work yet?
I don't know if I am particularly unlucky but every version of Op system I have tried either dies or just doesn't do anything after sign on even after leaving fora bout 20 minutes.  I have the 2gb 64 bit Pine and have tried to date Debian - gives up ghost after initial load!, Ubuntu started to look good but when trying to load firefox and Thunderbird stated something wrong and tried to report without success, gave up after 20 minutes staring at the aport icon.
I used to run various flavours of Linux including Fedora, Ubuntu and Suse on Intel Pcs so am not frightened to dig in a try things but really don't know where to start.  Indeed ran my business on Linux for a number of years before transferring to Apple.
Can any one recommend a working Linux distro for the pine 64 2GB or do I give up and buy a Raspberry?
Which microSD card are you using?
My forum topics:
• Create a WiFi hotspot on Debian 8
• Turn your Pine64 into a music server with mpd
• Adjust brightness of LCD on Armbian Desktop with 1 click
• My cases for Pine64 (acryl, lego & wood)
• Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
(04-21-2016, 11:24 PM)ianrob99 Wrote: I don't know if I am particularly unlucky but every version of Op system I have tried either dies or just doesn't do anything after sign on even after leaving fora bout 20 minutes.  I have the 2gb 64 bit Pine and have tried to date Debian - gives up ghost after initial load!, Ubuntu started to look good but when trying to load firefox and Thunderbird stated something wrong and tried to report without success, gave up after 20 minutes staring at the aport icon.
Firefox is still known to be broken, don't know about Thunderbird. Ubuntu Xenial with longsleeps image works fine for me with the Pine64+.
Did just try Thunderbird, it worked fine for me also, could add my account and read mails...
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
(04-21-2016, 11:33 PM)JulianM Wrote: Which microSD card are you using?
I have 2 cards currently , one is an Apacer 16GB and the other is a Sandisk 32GB
I ran Ubuntu just fine. There are some messages about crashing programs at startup but nothing that stopped it from working. Had a running Apache Server on the Pine and it all worked well. I used longsleeps images. I realize that this post doesn't really help you but I thought I'd answer the question in the title.
There must be something else wrong.
Seems like you were at a similar point and the question is more: Is there a OS that qualifies for being usable in a productive environment, aka for using the Pine as a Desktop replacement, right? Maybe you could specify your use case, to allow for more reasonable answers. Have you tried Remix OS?
  How to get Netflix to work in Chromium or Firefox on PBP User 17828 13 31,447 09-24-2020, 08:52 AM
Last Post: solostian
  Will the Rock64 work as a mobile data storage device? Kennetht 1 5,212 03-29-2018, 10:07 AM
Last Post: xalius
  7" Screen - Does it work with Debian abasel 1 6,249 07-26-2017, 05:44 AM
Last Post: pfeerick
  Would the SOPINE modules work if they were put into a standard SODIMM RAM slot? Wiooooo 4 10,926 02-05-2017, 02:57 PM
Last Post: MarkHaysHarris777
  Just Received my Order; It Doesn't work?! kikootwo 4 11,655 08-11-2016, 09:05 PM
Last Post: Mpoint
  Helpful Hint: HDMI-to-DVI cables do not work on PINE64 aegrotatio 4 12,930 06-07-2016, 11:02 PM
Last Post: aegrotatio
  Unable to get edimax wifi dongle to work with archlinux on Pine64 g3tinmybelly 9 20,215 04-27-2016, 06:48 PM
Last Post: g3tinmybelly
