Would the SOPINE modules work if they were put into a standard SODIMM RAM slot?
Yeah If I put a module of SOPINE in a standard motherboard, would it work as a processor/RAM? I'd like to put 8 of them in a server motherboardWink
(02-05-2017, 12:19 PM)Wiooooo Wrote: Yeah If I put a module of SOPINE in a standard motherboard, would it work as a processor/RAM? I'd like to put 8 of them in a server motherboardWink
I think not m8 (anyone correct me if im wrong)
No, absolutely not.
... the only thing at all similar about sopine and sodimm is the socket itself ( the hardware ).  The sopine is NOT compatible with any other hardware that uses the sodimm socket ( which is normally used for memory modules ).
The sopine is also not at all compatible with the RPi compute module;  completely different hardware, architecture, memory and PMCI.
No, absolutely not.
Thanks, I'm kinda new to hardware, but I've done a fair amount of code so I want to get started, so would there be a way to hook up more than one of the SOPINE baseboards to each other so that the computer would have more processing power without making a cluster computer?
No, absolutely not.
Yes, but you might want to wait on that;  tllim indicates some time ago that they are producing a commercial product that will take multiple sopine modules ( I think up to seven ).  Stay tuned.
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,510 08-24-2021, 08:17 AM
Last Post: lamson
  How to get Netflix to work in Chromium or Firefox on PBP User 17828 13 29,987 09-24-2020, 08:52 AM
Last Post: solostian
  1 of 7 SoPINE compute modules not receiving DHCP lease ClusterMaker 2 5,758 09-08-2020, 03:03 AM
Last Post: Dippywood
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 3,665 09-03-2019, 11:57 PM
Last Post: hbaxmann
  sopine cluster board install Smurfbot 1 6,536 03-31-2018, 04:09 AM
Last Post: pfeerick
  Will the Rock64 work as a mobile data storage device? Kennetht 1 4,970 03-29-2018, 10:07 AM
Last Post: xalius
  Sopine A64 doesn't boot ubuntu stixcher 5 12,071 12-03-2017, 11:05 AM
  7" Screen - Does it work with Debian abasel 1 5,911 07-26-2017, 05:44 AM
Last Post: pfeerick
  Turning off RPI GPIO 5v on boot (SOPine) TeknoRapture 1 4,669 03-31-2017, 02:48 PM
Last Post: xalius
  Sopine compatibility with Pi Compute temcocontrols 7 16,665 02-12-2017, 09:28 PM
