Rock64 and USB 3.0 HDD + USB 2.0 CC2531 doungle
Hello.
I have Rock 64 with connected HDD to USB 3.0 and CC2531 doungle (Zigbee sniffer) to USB 2.0
In this configuration HDD works fine, but CC2531 work very bad - working distance to Zigbee devices is 2-3 meters (must be 10-15).
Then I disconnect HDD from USB 3.0 - CC2531 work fine! Zigbee devices connect at 10-15 meters from Rock64.
I try connect CC2531 to USB 3.0 (HDD is OFF) - and in this configuration also all working fine.
But I need connect HDD and CC2531 simultaneous...
Whats problem can be?
have you tried to use an usb2 extension for your CC2531 dongle?
sometimes an usb3 connector near a wireless device can disturb the wireless transmission.
regards
(02-04-2019, 03:35 AM)pas059 Wrote: Hi,
regards
Hi.
I try usb-extender (1 meters lenght) - and it's helped.
CC2531 working good, working distance Zigbee devices - 10-15 meters.
I will continue to experiment. Basic version - something (HDD+USB-SATA adapter) interferes with CC2531.
regards
Thank you so much! I had been testing a few different things to try to solve this, connectig through the usb2 extender solved my issues!
Great!
  Are HW design files available for ROCK64? irenek 3 4,780 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 331 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,069 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 624 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,232 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,749 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,531 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,629 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,537 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,049 09-28-2021, 03:07 PM
Last Post: TRS-80
