Is it possible to install a clean and official version of Ubuntu?
Hello guys,
I would like to install a clean and official version of Ubuntu.
Is it possible to install the ARM version published by Ununtu?
Link: https://www.ubuntu.com/download/server/arm
(01-20-2019, 05:35 PM)eduapof Wrote: Hello guys,
Did you ever get an answer to this?
No you can't just tried it, it won't boot
The iso versions typically distributed by distros will only work on systems with a BIOS/EFI. Since the RockPro64 doesn't have a BIOS, the closest thing you can get to a bootloader is using Uboot. Different SoC (rockchip, allwinner, etc) have defined different locations for the boot sector/block. This causes the unfortunate situation where each SBC vendor needs its own specific rootfs images.
Here is a very good video that explains this whole process and what progress will be made going forward
https://fosdem.org/2019/schedule/event/hw_uboot/
Thanks for sharing that video @mknawabi ... hopefully that will clear up my own understanding of uboot also! Big Grin
After scratching my head over WTH Canonical were distributing ISOs for ARM servers... (really, they have CD drives on them, do they? Angel ) ... I realised after turning over the documentation that they expect you to network book the images. But, there was one supported build that actually uses uboot... so there is hope yet that they will have some uboot friendly official images.
Either that, or use ayufan's images... they are based on the ubuntu rootfs, after all!
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,659 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Accidentally updated Ubuntu/ Revert possible? Thisone 0 517 04-19-2023, 12:03 AM
Last Post: Thisone
Question nand-sata-install on RAID-1 array ARMandHammer 1 896 02-12-2023, 03:10 AM
Last Post: igorp
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,363 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,446 02-19-2022, 06:44 AM
Last Post: sigmaris
  WORKING: GPU-accelerated Widevine Chromium for Ubuntu 64 twilite 0 1,693 09-13-2021, 11:02 AM
Last Post: twilite
Question Booting official Debian on RP64 arteeh 6 6,391 07-06-2021, 10:16 AM
Last Post: TRS-80
  How To Lay Hands on a True 64-bit Debian Install? vandys 4 4,091 12-01-2020, 06:12 AM
Last Post: as365n4
  Kernel Update from 4.4 (Ayufan) on Ubuntu 20.04 db579 3 5,374 10-22-2020, 01:12 PM
Last Post: dukla2000
  Bringing up a fresh Debian install (or trying) foresto 2 4,690 08-09-2020, 01:57 PM
Last Post: foresto
