problems getting android on rock64
I've been trying to use an eMMC adapter and tried burning the images "7.1.2. rooted emmc" and "8.1 emmcboot" to the emmc but when I place it in the rock64, it will not boot or even show an image over hdmi. What am I doing wrong here?
(01-15-2019, 03:03 AM)mranderson Wrote: I've been trying to use an eMMC adapter and tried burning the images "7.1.2. rooted emmc" and "8.1 emmcboot" to the emmc but when I place it in the rock64, it will not boot or even show an image over hdmi. What am I doing wrong here?
I get the same - Are you able to get the SD versions working? Also are you getting any output on the USB to TTL connection? From what i understand the boot process can take 10+ minutes for the first time.
One other thing to note - the default resolution is @ 1080. My monitor can't do that (it's an old lab monitor) and i thought it was a boot issue for a while.
  Android Images (ROCK64) pineadmin 77 236,075 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 12,291 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 12,576 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 10,835 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,170 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,911 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,157 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 10,489 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,104 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,315 09-18-2020, 07:58 PM
Last Post: BowerR64
