rockpro 64 upgrading OMV
built my new Rockpro64 NAS recently and setup OMV using Ayufan's 0.7.9: ggitlab-ci-linux-build-67 latest stable release.. the system works flawlessly with all my requirements
my question is, if I am to upgrade to the next release (pre release/stable release) should I just run the command as specified by Ayufan on his page as shown below or am I missing something here..
sudo apt-get update -y
sudo apt-get install linux-rock64 -y
sudo apt-get install linux-rockpro64 -y
thanks in advance..
(01-03-2019, 04:11 AM)denver2020 Wrote: built my new Rockpro64 NAS recently and setup OMV using Ayufan's 0.7.9: ggitlab-ci-linux-build-67 latest stable release.. the system works flawlessly with all my requirements
thanks in advance..
Since your use-case is NAS, then my advice is this - if it runs flawlessly, and all the things you want it to do work flawlessly, then don't update it.
Thumbs Up
thanks in advance..
thanks Luke,  that does make sense , I was only considering the option if the upgrade does bring better performance to existing setup based on release notes..
I did get a another response  from the OMV forum and would leave it below for anyone else interested.. just update via OMV UI . of course as Luke points out there could be unforseen risks in updating
thanks
link
https://forum.openmediavault.org/index.p...post192001
thanks in advance..
thanks
link
Yea, what tkaiser said. I generally update my setup  every few months. The one thing I had to do was switch to mainline due to some buffering issues in KODI players on 4.4 - never figured out the cause, but mainline resolved the issue for me.
  Can i use this Emmc for Rockpro 64 Supratec 2 5,260 12-20-2023, 09:12 AM
  red led blink on rockpro pine 64 Daniele14521 0 2,967 09-26-2022, 01:40 AM
Last Post: Daniele14521
  Is my rockpro dead? k0sm 6 10,976 12-30-2021, 07:32 PM
Last Post: Rocklobster
  Rockpro 64 with analog input jintao6889423 3 9,585 05-13-2021, 09:41 PM
  Fedora 32 on ROCKPro 64. joeblues91 4 11,292 07-26-2020, 12:12 PM
Last Post: revoman
  RockPro 64 MIPI Pinout carbotaniuman 3 8,959 05-21-2020, 03:41 AM
Last Post: dukla2000
  RockPro 64 V2.1 Boot problem only DDR Version ... message nutilius 5 11,980 05-02-2020, 03:26 AM
Last Post: freeviv
  Rockpro 64 maurora 1 4,670 05-24-2019, 09:50 AM
Last Post: Luke
  Basic question on the Nas case of the rockPro Slam 1 5,448 01-23-2019, 08:04 AM
Last Post: Slam
  Can't get Rockpro to boot Crnppscls 4 9,381 12-15-2018, 05:16 PM
Last Post: Crnppscls
