RockPro 64 V2.1 Boot problem only DDR Version ... message
Hi !
I have problem with starting any opsys from SD card.
When I try to boot, after switch the poer I see only message:
DDR Version 1.19 20190305
In
and nothing more
Previously I used different OSes (Armbian and NetBSD), but now I couldn't even go to u-boot (without sd-card I got nothing).
Any suggestions ?
My board is RockPro64 V2.1 2018-07-02
Nuti
(08-26-2019, 09:36 AM)nutilius Wrote: Hi !
In
and nothing more
Any suggestions ?
Nuti
Have you tried a different sdcard?
In
and nothing more
Any suggestions ?
Nuti
Hi thanks for reaction.
Yes I've tried 3 different cards with different systems. Two of them worked before.
Is there a solution to this problem? I have the same issue and changing the SD card as well as the boot image did not work.
Are you using the serial console to monitor the boot messages? When I connected all three wires of the serial console, it didn't boot (I believe it got stuck at the DDR message as well). When I connected the ground and RTX only everything worked fine. See also here: HOW TO - Connect the serial console
I have only connected Ground as well as RX as described in the HOWTO you mentioned.
Since the last post I tried different thing like disabling the SPI EEPROM or the EMMC slot. All those thing did not help so put the board away for an evening. The next day the same SD card worked just fine. Since the SD card the board booted on was the "known good" SD card I powered down the board and inserted another card. After powering the board the serial console got disconnected and after reconnecting I got the same problem as described earlier. I just get the two lines and nothing else.
For me, this almost feels like there is a multifuse (or Resettable fuse) blown somewhere but I could not find one in the schematic. But maybe this is a known behavior but I could not find any hint of that in the Wiki. Next time the board will boot again, I will try unplugging the serial adapter completely before reconnecting the power cable.
I also had the board running for multiple hours with connected serial console but I did not reconnect the power cable.
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 13,005 06-21-2025, 06:21 AM
Last Post: aleksei
  Can i use this Emmc for Rockpro 64 Supratec 2 5,272 12-20-2023, 09:12 AM
  enble boot after power loss/restore dkebler 18 30,757 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 228,925 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 4,646 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 14,017 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 14,333 05-18-2023, 10:46 AM
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,232 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  red led blink on rockpro pine 64 Daniele14521 0 2,968 09-26-2022, 01:40 AM
Last Post: Daniele14521
  u-boot locked on pine64pro ljones 1 4,683 09-06-2022, 10:32 AM
Last Post: ljones
