Armbian images available
#21
Check for major Armbian update. Debian Buster and more https://docs.armbian.com/Release_Changelog/
Download https://www.armbian.com/rockpro64/ or apt update & upgrade
Added Armbian Debian Buster Minimal (ROCKPRO64) 5.90 on Wiki and PINE64 Installer.
Added Armbian Debian Buster Desktop (ROCKPRO64) 5.90 on Wiki and PINE64 Installer.
Added Armbian Debian Stretch minimal (ROCKPRO64) 5.90 on Wiki and PINE64 Installer.
Added Armbian Ubuntu 18.04 Bionic Minimal (ROCKPRO64) 5.90 on Wiki and PINE64 Installer.
Updated Armbian Ubuntu 18.04 Bionic Desktop (ROCKPRO64) 5.90 on Wiki and PINE64 Installer.
Updated Armbian Debian Stretch Desktop (ROCKPRO64) 5.90 on Wiki and PINE64 Installer.
Updated Armbian Debian Buster Minimal (ROCKPRO64) 5.91 on Wiki and PINE64 Installer.
Updated Armbian Debian Buster Desktop (ROCKPRO64) 5.91 on Wiki and PINE64 Installer.
I tried to install Armbian on Pinebook Pro. It works, I can connect to wifi, install packages, but when I start Xorg, I see just a back screen, like there is some problem with display configuration. I guess I have to configure display output, but I am not sure how to do that. Any hint?
(10-29-2019, 02:18 AM)Wizzard Wrote: I tried to install Armbian on Pinebook Pro. It works, I can connect to wifi, install packages, but when I start Xorg, I see just a back screen, like there is some problem with display configuration. I guess I have to configure display output, but I am not sure how to do that. Any hint?
You will need the dtb, the kernel and modules from a Pinebook Pro image to make it work.
(10-29-2019, 02:51 AM)Luke Wrote: You will need the dtb, the kernel and modules from a Pinebook Pro image to make it work.
What it means exactly? Kernel and modules from Debian build or Ayufan's repo?
Id use ayufan's repo because Armbian use his kernel as far as I know. Grab ayufan's ubuntu build, take the dtb and kenel image from /boot and then you need the modules from rootfs - which should be in /lib/ somewhere.
Not surprise its work, when designs Pinebook Pro, we try to follow the Rockpro64 GPIO pin assignment and use back same peripheral chips as identical as possible :-)
(10-30-2019, 08:33 PM)tllim Wrote: Not surprise its work, when designs Pinebook Pro, we try to follow the Rockpro64 GPIO pin assignment and use back same peripheral chips as identical as possible :-)
I just expected that everything will work, when it is so identical Smile
First just drop in a PBP device tree into /boot. Then just edit extlinux with:
video=eDP-1:1920x1080@60
See if you get something on the screen. You will likely miss sound, bt/wifi, battery support, and a number other things but at least it will confirm that Armbian is bootable with a simple dtb swap.
  Expose /dev/mali0 in armbian pedromiguel.sanchez 2 2,018 07-25-2022, 04:52 AM
Last Post: pedromiguel.sanchez
  Enable DSI/TD Ports on Armbian (jammy) dkebler 0 947 06-16-2022, 06:56 PM
Last Post: dkebler
  Armbian Jammy-Running fairly stable Rocklobster 0 1,186 05-04-2022, 01:00 PM
Last Post: Rocklobster
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 91 88,994 04-03-2022, 01:44 PM
Last Post: davidlsbc
  Armbian is looking for maintainer for ROCKPro64 TRS-80 20 14,374 03-19-2022, 09:32 PM
Last Post: paralin1
  Armbian 22.02 Release Announcement TRS-80 0 1,165 02-28-2022, 05:08 PM
Last Post: TRS-80
  OpenMediaVault: link from wiki or Armbian? Goffi 0 1,176 02-10-2022, 03:57 AM
Last Post: Goffi
Bug Unreliable display in Armbian and Debian ksattic 3 3,182 11-17-2021, 05:42 AM
Last Post: PakoSt
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 1,894 10-29-2021, 11:15 AM
Last Post: TRS-80
  RockPro64 EDP in Armbian hannescam 2 2,547 10-15-2021, 09:07 AM
Last Post: hannescam
