Expose /dev/mali0 in armbian
Hi all,
I am managing a cluster of Rock64/RockPro64 and I need access to the GPU cycle counters (I already got access to CPU cycle counter) of the Mali T860 included in the board. I am trying to use the HWCPipe (https://github.com/ARM-software/HWCPipe) interface to get the CPU counters. However, this library tries to use /dev/mali0 to interact with the GPU, which is not exposed to the user in armbian using the Panfrost driver.
I have tried several ways of installing the mali midgard driver without success so far. Besides, I have tried to use /dev/dri/card1 (and 0) as resource for HWCPipe, but it doesn't work either.
Does someone know how I could expose the /dev/mali0 interface to userspace using panfrost driver or how to install mali-midgard driver in the last armbian version (kernel 5.15.48)?
The same posted here applies for Rock64 with lima driver for Mali-400 GPU, just in case...
the panfrost driver does expose performance counters, though I don't know precisely through what kind of interface. Collabora wrote an article about using perfetto to access panfrost performance counters, which might be useful.
Kernel code seems to be in drivers/gpu/drm/panfrost/panfrost_perfcnt.c.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
Hi, Thanks for your reply. I also checked that link before, but technically, what I would like to do is just gather the GPU cycles and embed the code in my application. I will try perfetto just to see how it works and see if I can adapt something
  Armbian images available Luke 60 87,342 08-04-2022, 06:56 AM
Last Post: Rocklobster
  Enable DSI/TD Ports on Armbian (jammy) dkebler 0 939 06-16-2022, 06:56 PM
Last Post: dkebler
  Armbian Jammy-Running fairly stable Rocklobster 0 1,178 05-04-2022, 01:00 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 91 88,433 04-03-2022, 01:44 PM
Last Post: davidlsbc
  Armbian is looking for maintainer for ROCKPro64 TRS-80 20 14,257 03-19-2022, 09:32 PM
Last Post: paralin1
  Armbian 22.02 Release Announcement TRS-80 0 1,156 02-28-2022, 05:08 PM
Last Post: TRS-80
  OpenMediaVault: link from wiki or Armbian? Goffi 0 1,169 02-10-2022, 03:57 AM
Last Post: Goffi
Bug Unreliable display in Armbian and Debian ksattic 3 3,159 11-17-2021, 05:42 AM
Last Post: PakoSt
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 1,880 10-29-2021, 11:15 AM
Last Post: TRS-80
  RockPro64 EDP in Armbian hannescam 2 2,531 10-15-2021, 09:07 AM
Last Post: hannescam
