HBA Card working on Aufan's builds but not in debian, armbian or dietpi
I've got a HBA card (IBA H1110) in the pci express slot of my rockpro64.
It works flawlessly on auyfan's builds.
But Armbian etc fail to boot with the card in the slot. I see vertical yellow green lines after the initial boot sequence and then nothing.
What exactly does aufan do differently in his builds? Is it possible to make an armbian build that will work too?
Even though Armbian publish images, Armbian is actually primarily a build script, so you can do whatever you like.[0]
The rub is finding out what those differences are. There are places where you can include additional patches in the build, instructions for that are in the docs.
But you are going to be on your own there, hacking unsupported in uncharted waters. Maybe make a thread / search existing ones and see if anyone else has [solved] the problem already?
Good luck with it, if you do figure it out, by all means please share the solution back to Armbian (preferably in a PR, but anything helps)!
[0] In fairness, it even took me a long time to understand this, even though I been hanging around over there for years.
Cheers,
TRS-80
Protocols, not Platforms
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,491 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 565 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,354 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian images available Luke 60 87,824 08-04-2022, 06:56 AM
Last Post: Rocklobster
  Expose /dev/mali0 in armbian pedromiguel.sanchez 2 2,009 07-25-2022, 04:52 AM
Last Post: pedromiguel.sanchez
  Enable DSI/TD Ports on Armbian (jammy) dkebler 0 941 06-16-2022, 06:56 PM
Last Post: dkebler
  Armbian Jammy-Running fairly stable Rocklobster 0 1,182 05-04-2022, 01:00 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 91 88,793 04-03-2022, 01:44 PM
Last Post: davidlsbc
  Armbian is looking for maintainer for ROCKPro64 TRS-80 20 14,337 03-19-2022, 09:32 PM
Last Post: paralin1
  Armbian 22.02 Release Announcement TRS-80 0 1,163 02-28-2022, 05:08 PM
Last Post: TRS-80
