Flashing Libre Computer ROC-RK3328-CC rom to ROCK64
Exclamation
Hi guys.
After multiple attempts to get a regular "tablet" Android version for Rock64 board I came across the ROC-RK3328-CC board from Libre computer which is very similar to Rock 64.
So I decided to create a hybrid rom using the Android 7.1.2 from Rock64 and ROC-RK3328-CC. However before trying this I would like to hear your opinions if this will work.
Here are the suggested steps
1. Download the Android 7.1.2 rom for  ROC-RK3328-CC  from here
2. Open Android Tool Firmware tab and load the rom as shown in the image
[Image: 12293903.png]
3.Take the original Rock64 7.1.2 Rom (EMMC version) and unpack it using the 3rd tab in Android Tool
[Image: 12293949.png]
4. Go to the first tab and check the following options Loader, Parameters and Resources
[Image: 12294010.png]
5. Select the checked files from the output folder where we unpacked the original Rock64 rom
6. Just to make sure that we get no errors, disconnect the device, wait 30 sec, reconnect it in Maskrom mode
7. Press Run.
What are the chances that this will work?
Any suggestions?
  rock64-android10-tv patchset for Firely AlexS 1 598 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 245,111 11-18-2024, 08:21 AM
Last Post: reukiodo
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,610 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,501 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 11,319 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,962 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 16,260 09-09-2020, 08:44 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 43,773 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 6,286 06-04-2020, 02:23 AM
Last Post: eugenev13
  Android 10 for Rock64? Blinky 0 6,093 04-21-2020, 12:55 AM
Last Post: Blinky
