Android 8.1 build procedure
I'm quite newbie for the building android images. Just downloaded ROCK64_RK3328_android8.1.tar.gz and run mkimage.sh. It ended up with
kernel image not fount![/data/store/eg/Rock64/rk3328v81_box/out/target/product/rk3328_box/kernel]
copy kernel from TARGET_PREBUILT_KERNEL[] (y/n) n to exit?y
cp: missing destination file operand after '/data/store/eg/Rock64/rk3328v81_box/out/target/product/rk3328_box/kernel'
Try 'cp --help' for more information.
seems that there's no kernel in some place. What else do i need?
thanks
No one can give a small hint?
I did manage to build kernel within that tree. But i have no idea what mkimage.sh needs to work:
CROSS_COMPILE=/opt/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- ARCH=arm64 ./mkimage.sh
TARGET_BOARD_PLATFORM=rk3328
TARGET_PRODUCT=rk3328_box
TARGET_HARDWARE=rk30board
TARGET_BUILD_VARIANT=userdebug
BOARD_SYSTEMIMAGE_PARTITION_SIZE=1610612736
BOARD_USE_SPARSE_SYSTEM_IMAGE=true
TARGET_BASE_PARAMETER_IMAGE==device/rockchip/common/baseparameter/baseparameter_fb720.img
system filesysystem is ext4
I tried to set variable TARGET_PREBUILT_KERNEL to /data/store/eg/Rock64/rk3328v81_box/kernel/arch/arm64/boot/Image.gz but without success.
Can you just drop a small hint ? I'm not asking for user guide really..
  Android Images (ROCK64) pineadmin 77 244,303 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,176 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,463 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,614 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,705 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,403 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,574 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,190 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,501 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,868 09-18-2020, 07:58 PM
Last Post: BowerR64
