Using the CP2102 chipset USB-TTL with the Rock64
Instead of using the USB-TTL adapter with the CH340G chipset like in the official shop, I'm using one with CP2102.
I'm trying to install OpenBSD on my SBC through serial, and I'm seeing text through the console just fine.
I just can't type anything.
So, again - receiving data is fine, transmitting data to the board is a no-go.
Using "sudo minicom -8 -D /dev/ttyUSB0 -b 115200" as per the BSD install tutorial in the other thread.
Yes, I DID use the baud rate of 1500000 while setting up the microsd to boot the install the first time. That required no input, so I didn't notice the problem.
Testing it now, baud rate doesn't matter - I can't input anything through serial into the running board regardless.
So, I'm ordering the CH340G USB-TTL to see if this is a compatibility problem and I already have a second Rock64 on the way. I'm just wondering if anyone has any ideas to perhaps make this work as is.
Also, I'll post any relevant updates.
Thank you for your time.
Just tested the serial TTL USB with another Rock64. Same issue - no input.
Most likely a hardware incompatibility.
Looks like I'll be waiting on the serial adapter for a few weeks.
  Are HW design files available for ROCK64? irenek 3 4,786 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 335 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,071 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 625 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,236 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,749 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,532 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,629 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,541 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,053 09-28-2021, 03:07 PM
Last Post: TRS-80
