04-01-2016, 10:18 AM
NTSC no use to me
Successful Bootup
NTSC no use to me
04-01-2016, 10:00 PM
(03-31-2016, 01:09 PM)montyflange Wrote: OK got it to boot now into Remix OS but all the menu bars and that are on the outside of the TV edge. I have managed to right click and get display settings but there is no option to change resolution, refresh rate etc . How can I get it to change those now ? WE have mentione dthis limitation to Remix folks and they are working on the solution.
04-02-2016, 06:00 AM
My Pine did the same, but I went into my TV settings and selected Auto screen size, it synced with RemixOS and there's no overscan.
If I've helped you with something, please leave a rating for my responses.
woo-hoo! think i got it to start up. i got this linux opening trace crawl, at least, on a ProScan UltraHD 4K screen. we'll see!
best, — faddah portland, oregon, u.s.a.
04-04-2016, 04:25 AM
(03-31-2016, 01:09 PM)montyflange Wrote: OK got it to boot now into Remix OS but all the menu bars and that are on the outside of the TV edge. I have managed to right click and get display settings but there is no option to change resolution, refresh rate etc . How can I get it to change those now ? I had the same. There is likely to be something on the TV itself to fit to screen. No need to change anything on the board or OS. (04-04-2016, 04:25 AM)patmolloy Wrote:Thats correct. The adjustment must be done on the tv/monitor itself.(03-31-2016, 01:09 PM)montyflange Wrote: OK got it to boot now into Remix OS but all the menu bars and that are on the outside of the TV edge. I have managed to right click and get display settings but there is no option to change resolution, refresh rate etc . How can I get it to change those now ?
04-12-2016, 09:16 PM
Board: 2GB A64-2GB-Rev 6 2016-02-25
After a day or so of trying all of the various images I got my board booting the Ubuntu image linked from the PINE64 wiki: Ubuntu Image I have two caveats so far: 1. Do not use a DVI-HDMI adapter. I could only get video output with a straight HDMI cable to an HDMI monitor. 2. Make sure your USB power supply is at least 5V/1.5A. Boot up will die early if your USB power supply is something like 5V/0.2A or 5V/0.75A. Also, if you're a Linux user, I'll be starting PINE64 docs at: http://elinux.org/Pine64 Good luck Bill
04-16-2016, 10:52 AM
How to fix it? My monitor only works with DVI.
04-16-2016, 04:26 PM
06-19-2016, 06:56 PM
Any news on the edge issue/overscan...looks like this was being discussed two months ago...are we years away from a usual Pine64?
Thanks, JT |
Graphical glitch after bootup | kylev2015 | 2 | 3,988 |
04-22-2016, 06:32 AM Last Post: tllim |
