rock64 lan disconnected with atv 7.1 (0.3.13)
The lan is disconnected in rock64 atv 7.1 (auyfan git android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz).  Works just fine with rock64 stock android v7.1 and 8.1.  Using microSD versions for all.  Flashing back and forth and can repeat results:  atv 7.1 (lan not working) and android 7.1/8.1 (lan works just fine).  Using same DHCP settings for both.
I could have sworn atv 7.1 worked first time and stopped working after re-flashing with android 8.1.  Perhaps android 8.1 installed low level firmware that isn't compatible with atv 7.1?  Any thoughts on how to test this theory or how to re-flash low-level firmware back to factory defaults?
Thanks,
Tim
My bad.  I just realized I had been installing the rockbox atv version (android-7.1-rock-64-rockbox_atv-v0.3.13-r115-raw.img.gz ) and not the rock64 atv version (android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img.gz).  LAN works just fine with the correct binary installed on the rock64.
Glad this is resolved.  It was driving me nutz.
  rock64-android10-tv patchset for Firely AlexS 1 208 09-08-2026, 10:49 PM
  Android Images (ROCK64) pineadmin 77 242,107 11-18-2024, 08:21 AM
Last Post: reukiodo
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,194 08-04-2021, 07:35 PM
Last Post: Rocklobster
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,243 03-12-2021, 01:38 PM
Last Post: Wizzard
  Android on Rock64 SD Problem ElBoluTony 3 10,952 10-07-2020, 12:10 PM
Last Post: ElBoluTony
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,713 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 15,891 09-09-2020, 08:44 AM
Last Post: BowerR64
Question Regular Android build for Rock64? fender90 18 42,761 09-09-2020, 08:04 AM
Last Post: BowerR64
  Minimum requirements for ROCK64 Android install? eugenev13 0 6,149 06-04-2020, 02:23 AM
Last Post: eugenev13
  Android 10 for Rock64? Blinky 0 5,930 04-21-2020, 12:55 AM
Last Post: Blinky
