wiki Android TV 7.1 file error
http://wiki.pine64.org/index.php/ROCK64_...oid_TV_7.x
MD5 equally
After the installation,display ubuntu 16.04  Huh Huh Huh
Waste time
Please correct it
Thank you
Ok, will look into it on monday. For now, you can get android A7.1 ATV build in all variants (raw, rkflashtool, and update) from ayufan's git.
No, that's correct. It's a build of "Ubuntu 16.04.3 LTS rock64" which will write the Android image to eMMC... hence the microSD to eMMC in the title [Image: wink.png]
If you have an HDMI monitor/TV connected, it would have told you it was either 1) writing the image to eMMC if you had an eMMC connected, or 2) that it wasn't detected and then halted.
(07-09-2018, 06:57 PM)pfeerick Wrote: No, that's correct. It's a build of "Ubuntu 16.04.3 LTS rock64" which will write the Android image to eMMC... hence the microSD to eMMC in the title [Image: wink.png]
I'm sorry,I don't see it carefully.
  Android Images (ROCK64) pineadmin 77 235,342 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 12,247 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 12,522 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 10,765 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,150 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 6,879 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,126 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 10,448 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,081 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 8,267 09-18-2020, 07:58 PM
Last Post: BowerR64
