Stock Android Oreo 8.1 release
#31
(07-13-2018, 07:30 AM)pfeerick Wrote: It generally 'just worked' after some minor gremlins like the Play Store were fixed up, and the rock64 was happily playing videos and browsing the net without any major issues...
Does the 8.1 image work with the USB 3 port? I'm currently running Android 7.1.2 and if I plug anything into the USB3 port it stutters terribly.
(07-24-2018, 04:05 PM)OfficialRiderPride Wrote: Does the 8.1 image work with the USB 3 port? I'm currently running Android 7.1.2 and if I plug anything into the USB3 port it stutters terribly.
Interesting observation regarding USB 3 port on Rock 64.
I have the same problem with LE.
https://forum.libreelec.tv/thread/12151-...#post95591
I created with dd directly to usb mmc.
It boots but freezes. It does it enough to be unusable.
Same result with every Android image on either mmc or sdcard excluding Android 7.1.2 Stock Image.
4GB boards are lemons  Angry
(08-02-2018, 11:52 AM)dougunder Wrote: I created with dd directly to usb mmc.
Use Pine Installer. I tested Android stock on eMMC and preferred ayufan Android TV .
I also run LibreELEC devel-20180708142741-4dc93d7 SD Card
Very good results. Whilst not 100% these images are over 90% stable.
Android TV is very stable. Kodi from App Store works. Refresh rate change working as well.
Give it a shot and then retract the lemon quote.
You purchased a Development Board. So you are a tester as well as all others in various forums.
(06-27-2018, 10:34 AM)dkryder Wrote: play store did not work for me. error message states the play store app installed with the build was not compatible with the device. error message states to uninstall updates however that option is not present. tried updating to newer play store but that did not work.  also, the security update is as of feb 2018. for a build compiled on what looks like last week.
I just tried it and had the exact same problem. Also, it didn't work with the dual Rock64 USB 3.0 (RTL8812AU) wifi adapter. It did work with wired Ethernet, but still no Play Store.
You must go to apkmirror (like suggest Pfeerick here https://forum.pine64.org/showthread.php?...3#pid39113) and download latest "Google play Android tv" , "Google play services for Android tv" and install. It works juste fine.
What about bluetooth support here ?
Sorry if that was asked already..
Do we still flash sdboot image to eMMC via USB2eMMC adapter?
The box boots to 8.1.0 recovery and does not boot OS after flashing.
Tried wipe cache and data and reset to factory but no success
Getting back to 7.1.2. Completely unusable image.
Here is what i see on 8.1 boot (flashed sdboot to eMMC via USB adaptor):
https://drive.google.com/open?id=1Bxldw9...rHJTp1anNV
(06-25-2018, 01:48 PM)Luke Wrote: Just a heads-up, looks like the eMMC boot image is iffy on some boards. In other words, it may not work 100%. SD boot works fine however.
Hi Luke,
Can you please let me know the build procedure for Android 8 , we are struck at last step of packaging of all images.
Can you please kindly help, we need it urgently.
Thanks & Regards,
Mahesh
Hi Luke,
Thanks & Regards,
Mahesh
Sadly, I have no such insight. I strongly suggest you try reaching out to ayufan or ayaka in the IRC.
Hope this helps.
I tried several times flashing 8.1 with AndroidTool on EMMC, but after first reboot all I get is a black screen. 7.1.2 works fine however. Any1 managed to flash 8.1 on EMMC? (if yes, how??)
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,274 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,033 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,558 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,608 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,026 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,504 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,021 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,580 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,729 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,814 09-09-2020, 08:44 AM
Last Post: BowerR64
