I updated the bionic to 0.6.49, after rebooting the system does not load at all
After the update, it does not load
06-03-2018, 05:55 PM
(06-03-2018, 08:56 AM)zet_lab Wrote: I updated the bionic to 0.6.49, after rebooting the system does not load at all I wouldn't update the rock64 past 0.6.44 (maybe 0.6.45). Focus is currently on the rockpro64, as they are generated from the same source, so something may (and probably has) for the rock64 on the way. But thanks for the report.
06-05-2018, 08:57 AM
(06-03-2018, 05:55 PM)pfeerick Wrote:(06-03-2018, 08:56 AM)zet_lab Wrote: I updated the bionic to 0.6.49, after rebooting the system does not load at all This means that we can no longer do "apt upgrade"? Or is there another way to just block the version update to keep the 0.6.44? I'm in the same situation, I have a rock64 1GB with the stretch minimal 0.6.44 image installed. Thanks
06-05-2018, 09:57 AM
(06-05-2018, 08:57 AM)matteobp Wrote:(06-03-2018, 05:55 PM)pfeerick Wrote:(06-03-2018, 08:56 AM)zet_lab Wrote: I updated the bionic to 0.6.49, after rebooting the system does not load at all https://forum.pine64.org/showthread.php?...8#pid37868 It works for me. I use it on the "development" board, test any update/upgrade or new installation there first, when all things done, swap the sd card with the "production" board. |
How to update/compile Debian 12.5? | Wizardknight | 3 | 466 |
03-29-2024, 05:01 AM Last Post: gedas07 |
Spinlock Lock after Firmware Update | Watcher | 4 | 4,100 |
02-18-2021, 08:52 PM Last Post: Rocklobster |
How can I update from Ubuntu 18 to Ubuntu 20? | gedas07 | 3 | 4,126 |
10-04-2020, 10:02 PM Last Post: tomarm |
Plex update on rock64 | croquin | 1 | 3,563 |
03-30-2019, 12:36 PM Last Post: pfworks |
Cant update package libgl1-mesa-dri | scalextrix | 2 | 4,271 |
02-16-2019, 06:20 AM Last Post: scalextrix |
OpenMediaVault fails to update | S265 | 3 | 9,263 |
08-23-2018, 06:28 AM Last Post: S265 |
Apt-get update duplicate entry error | Jxck | 1 | 3,031 |
06-02-2018, 02:26 PM Last Post: evilbunny |
