OpenMediaVault fails to update
Hi guys. The Rock64 OMV box throws up an error and refuses to update, using the "check" button on the Update Management Menu. Has anyone come across this? Any help appreciated.
Linux rock64 4.4.77-rockchip-ayufan-136 #1 SMP Thu Oct 12 09:14:48 UTC 2017 aarch64 GNU/Linux
Release: 3.0.99
Codename: Erasmus
"Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C; apt-get update 2>&1' with exit code '100': Ign file: InRelease Ign file: Release.gpg Ign file: Release Ign file: Translation-en Get:1 http://security.debian.org jessie/updates InRelease [44.9 kB] Get:2 https://openmediavault.github.io erasmus InRelease [14.8 kB] Hit http://packages.openmediavault.org erasmus InRelease Get:3 https://openmediavault.github.io erasmus-proposed InRelease [6125 B] Hit http://security.debian.org jessie/updates/main Sources Hit http://ppa.launchpad.net xenial InRelease Hit http://security.debian.org jessie/updates/contrib Sources Hit .........snip
(08-22-2018, 03:09 PM)S265 Wrote: Hi guys. The Rock64 OMV box throws up an error and refuses to update, using the "check" button on the Update Management Menu. Has anyone come across this? Any help appreciated.
Release: 3.0.99
Codename: Erasmus
Just tried it on one of my boards that i use as nas with OMV and check worked, selected all the packages, pressed upgrade, also worked (had about 10 outdated packages) and it rebooted normally and everything seems fine apparently...i suggest to try asking for help here: https://forum.openmediavault.org/index.p...0-General/
I just notice...im on OMV 4.1.9 arrakis, you are on 3 and AFAIK 3 is not updated anymore, maybe the update server is disabled allready too?
Source: https://www.openmediavault.org/?p=2282
If you see the links on the "news" section on that page you see that if you go back you can find the arrakis launch, the EOL notice and the 3.0.99 release news in that order so you have the latest version on erasmus anyway...
I just notice that they have 2 news pages about the 3.x EOL, they wanted to be really sure users are informed about that lol:
https://www.openmediavault.org/?p=2451
Some other people asked how to upgrade from 3 to 4 apparently from command line is as simple as issuing a single command:
omv-release-upgrade
Sauce:
https://forum.openmediavault.org/index.p...post159516
https://forum.openmediavault.org/index.p...post166844
Personally i would install 4.x from scratch but if you have a complex setup maybe its going to be annoying...
What Trash_Can_Man said is correct: you can't upgrade between 3.X.X -> 4.X.X
This isn't just on Rock64 images, this is for all systems running OMV. For more details please check OMV forum.
Ok thanks - got the message. I hope to reinstall sometime soon to get the latest version and skip the upgrade.
Thanks guys
  How to update/compile Debian 12.5? Wizardknight 3 397 03-29-2024, 05:01 AM
Last Post: gedas07
  Spinlock Lock after Firmware Update Watcher 4 4,061 02-18-2021, 08:52 PM
Last Post: Rocklobster
  How can I update from Ubuntu 18 to Ubuntu 20? gedas07 3 4,087 10-04-2020, 10:02 PM
Last Post: tomarm
  Plex update on rock64 croquin 1 3,546 03-30-2019, 12:36 PM
Last Post: pfworks
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,263 03-26-2019, 07:28 PM
Last Post: Poincare
  Cant update package libgl1-mesa-dri scalextrix 2 4,243 02-16-2019, 06:20 AM
Last Post: scalextrix
  After the update, it does not load zet_lab 3 4,894 06-05-2018, 09:57 AM
Last Post: cooker
  Apt-get update duplicate entry error Jxck 1 3,006 06-02-2018, 02:26 PM
Last Post: evilbunny
Heart Openmediavault vs RPI3: ONE HAPPY CAMPER! ElRobbo 2 3,484 04-25-2018, 10:16 PM
Last Post: mMe1824
