Possibly Dead Board?
Hi all, new to the forums here. I've had a Pine64 long running with OpenHAB. Recently something happened and I needed to put it on battery power. So I pulled it off it's nice shelf, and hooked it up with battery power. No issues. However, I do have a fan that came with the case. It plugged onto one of the pin sets to provide a fan over the SOC for cooling. When on battery power, it was looking to pull too much juice, so I disconnected it.
When I was done doing what I needed on battery power, I went to put things back together. I believe I may have plugged the fan power into a wrong pin set. Upon restart I was not able to get anything of use and I heard a funny noise and saw the fan start then stop immediately. Now it seems, when I attempt plugging this Pine into any power, I just get a solid red power LED and nothing else happens. No video output plugged into HDMI, No Ethernet connectivity, and no apparent signs of life.
What I'm curious of, is it possible I've somehow blown something in the board by putting the fan into the wrong pins? Or is it possible I've somehow triggered some special boot mode I don't understand? I'm just a bit lost as to what could cause this to not show any signs of life now.
Hoping someone here might have some insight as to how I can fully validate or knows if its just simply possible and very plausible I've fried something.
(04-03-2018, 10:59 AM)1activegeek Wrote: Hi all, new to the forums here. I've had a Pine64 long running with OpenHAB. Recently something happened and I needed to put it on battery power. So I pulled it off it's nice shelf, and hooked it up with battery power. No issues. However, I do have a fan that came with the case. It plugged onto one of the pin sets to provide a fan over the SOC for cooling. When on battery power, it was looking to pull too much juice, so I disconnected it.
Most of fan power is 12V and for sure will kill the board when plug in wrongly :-(
(04-03-2018, 06:34 PM)tllim Wrote: Most of fan power is 12V and for sure will kill the board when plug in wrongly :-(
Thank you. I was assuming that's the case, but wanted to validate I couldn't have put it into some type of (scute the analogy) special mode like with iPhons flashing in DFU mode. I know it won't snap out of it until it's had a specific scenario applied.
Just to be sure here, I am talking about plugging the fan lead cable into the PINs on the board vs having the pins on the board plugged into other random pins. So the power I thought would be generated from the board going to the fan, vs the fan actually producing power, and causing a short. If anything I was thinking it was more in line with potentially jumping 2 pins that shouldn't be, that are close to the fan pins.
  How to build Webradio from Board A64 ? Bebert 5 12,406 08-19-2020, 12:49 PM
Last Post: Bebert
  PINE64 board not powering up loki21century 2 8,829 11-25-2019, 12:19 PM
Last Post: Partymack711
  dead Pine A64? Truglio 2 6,885 01-22-2019, 10:06 AM
Last Post: Truglio
  Pine64+ 2GB board for sale with WiFi module and case ~clumsy~ 1 5,636 10-21-2018, 04:54 AM
Last Post: aeiltz
  LED flashes for 1 second, board won't boot Audioslave 2 6,839 08-02-2018, 10:28 PM
Shocked Selling my PINE64 2GB+ board with WIFI/BT module and extras $30 or best bid in ebay moondark 0 3,737 04-14-2018, 12:31 PM
Last Post: moondark
  Running UniFi Controller on a Pine A64+ 1Gb board ishwest 7 42,455 07-15-2017, 09:24 AM
Last Post: smills
  Welcome home, Pine64 board! JulianM 11 24,506 03-19-2017, 04:40 PM
Last Post: xalius
  Keeping board cool clarkss12 3 7,094 02-23-2017, 10:29 PM
Last Post: pfeerick
  Slim line Pine Board adamjedgar 0 3,440 02-22-2017, 09:58 PM
Last Post: adamjedgar
