LAMP on Rock64
Sad
Hello everyone, I'm Matteo. A few days ago I'm trying to install a web environment on 4GB Rock64. I tried both with Debian and Ubuntu, but I had installation errors on MariaDB and PHP. Sometimes I've had kernel panics. Confused
What can I do?
What is the best distro to make a LAMP environment on Rock64?
thanks.
A kernel panic after a fresh install with automatic reboots isn't unusual... last time I saw that there was even a message indicating that it was being automatically fixed so it didn't happen again - so it may be something to do with self-tuning.
However, for a LAMP stack OS I would recommend either the xenial-minimal or xenial-containers rock64 builds - try both the "stable" (currently 0.5.15) and "testing" (currently  0.6.28) builds. I'm running the 0.6.25 container build on both SD and eMMC with no issues, and prefer the container build so things like MariaDB, apache, plex, etc, can run in docker containers... If you're still having trouble, maybe try the Armbian rock64 builds...
(03-31-2018, 03:45 AM)pfeerick Wrote: A kernel panic after a fresh install with automatic reboots isn't unusual... last time I saw that there was even a message indicating that it was being automatically fixed so it didn't happen again - so it may be something to do with self-tuning.
okay, thanks for your esplanation.
 I will try with xenial-minimal
I agree with using the Community Build Xenial Minimal Linux Kernel Armbian build.
http://wiki.pine64.org/index.php/ROCK64_..._0.4.16.5D
Good luck!
i made a lil tut on how i got my LAMP + Java/Tomcat webserver working on Debian Stretch minimal : https://forum.pine64.org/showthread.php?...7#pid36807
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,121 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 2,191 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,295 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,277 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,230 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,348 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,538 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,485 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 88,105 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 111,493 09-01-2024, 06:05 AM
