Laptop as a bridge for Rock64's internet connection
Hi all!
I've just got a Rock64, burned the official image (minimal Debian), connected to the monitor and the keyboard, launched it and... realized I need an internet connection. For this I can use a laptop (Debian again) connected via WiFi, which has one Ethernet port free. I've got some general descriptions about bridging and routing in Linux having WiFi but nothing worked so far. Say, I have a difficulty to connect to the Ethernet port of the WiFi access point. I believe it's quite a common case. Could someone, please, help me and provide a real case example solving such problem?
I'll specify the details.
There is a WiFi network 192.168.0.0/24 with the access point at 192.168.0.1 and the laptop at 192.168.0.8.
Assume the laptop has to act as a router. Following the aforementioned instructions I've created network 192.168.0.0/24 the the Ethernet interface of the laptop has ip 192.168.2.1. All the commands:
sudo ifconfig eth0 up sudo ifconfig eth0 192.168.2.1 echo 1 | sudo tee /proc/sys/net/ipv4/ip_forward sudo iptables -t nat -A POSTROUTING -o wlan0 -s 192.168.2.0/24 -j MASQUERADE
Locally, now you can ping both laptop's ips: 192.168.1.8 and 192.168.2.1. The current config is:
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000    link/ether ETH0-MAC brd ff:ff:ff:ff:ff:ff    inet 192.168.2.1/24 brd 192.168.2.255 scope global eth0       valid_lft forever preferred_lft forever 3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000    link/ether WLAN0-MAC brd ff:ff:ff:ff:ff:ff    inet 192.168.1.8/24 brd 192.168.1.255 scope global wlan0       valid_lft forever preferred_lft forever
Then I've set the rock64's Ethernet interface using `nmtui`: ip is 192.168.2.2/24, gateway is 192.168.2.1. From now I can ping local ip 192.168.2.2 but not the gateway. Checking the laptop's arp table I can't see the MAC of the rock64. Hence, I guess, no packets even sent via the cable.
So, the question is... what to do next?
Made a typo at the previous post. The correction is:
Quote:There is a WiFi network 192.168.1.0/24 with the access point at 192.168.1.1 and the laptop at 192.168.1.8
I've solved this issue using the built-in Network Manager of my distro. There I've selected "Shared to others computers" for the wired connection. I've canceled all the changes to all configuration files I made before. That's it, everything works automatically from both sides, the laptop and the Rock64.
However, the manual setup is still a miracle for me.
  PineBuds Pro - pairing from laptop cli - one earbud only c6Q$! 2 5,528 02-17-2023, 11:41 PM
Last Post: zer0sig
  MRAA Rock64 support jbize 2 5,666 07-09-2022, 04:40 AM
Last Post: igorp
  Newbie unable to connect to internet Derek7 2 6,184 07-16-2021, 12:41 AM
Last Post: Derek7
  Rock64 with Debian netinst usb Bloris 6 15,128 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 7,561 06-12-2019, 10:44 PM
Last Post: evilbunny
  Custom Kernel for ROCK64 mayst 2 8,059 01-07-2019, 08:04 AM
Last Post: mayst
Bug Rock64 Login lpninja 1 7,340 10-04-2018, 12:02 AM
  Rock64 suitable for headless TVHeadend install? elsmandino 3 10,294 06-26-2018, 11:37 AM
Last Post: Luke
  Will the Rock64 work as a mobile data storage device? Kennetht 1 5,268 03-29-2018, 10:07 AM
Last Post: xalius
  Rock64 OS eMMC boot ProfessionalDreamer 2 8,169 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
