Guide - XRDP - Debian Stretch / Ubuntu Xenial / OMV
Preface
This quick and simple guide will show how to connect to your Rock64 with Windows native Remote Desktop Connection client.
Prerequisites
ROCK64 board running Debian or Ubuntu, connected to the local network
Access to terminal, either locally or via SSH
Some basic understanding of using the linux terminal
____________________
Debian:
Make sure you do not have any other VNC servers installed like vnc4server or tightvncserver.
sudo apt remove xrdp vnc4server tightvncserver
Install xrdp and tigervnc server
sudo apt install -y xrdp tigervnc-standalone-server
Swap places Xorg with Xvnc so Xvnc goes first.
sudo nano /etc/xdrp/xdrp.ini
Connect via Xvnc (first in the client list) with native Windows Remote Desktop client.
Ubuntu (the same setup as Raspberry PI):
Remove other VNC servers
sudo apt-get remove xrdp vnc4server tightvncserver
Install tightvncserver and xrdp
sudo apt install -y tightvncserver xrdp
Connect via Xorg (first in the client list) with native Windows Remote Desktop client.
OMV armhf:
Download:
libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
https://packages.debian.org/jessie/armhf...0/download
xrdp_0.6.1-2_armhf.deb
https://packages.debian.org/jessie/armhf/xrdp/download
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u7_armhf.deb
sudo dpkg -i xrdp_0.6.1-2_armhf.deb
Thanks for writing this up :-)
(02-07-2018, 05:02 AM)S3phi40T Wrote: Preface
Prerequisites
Debian:
OMV armhf:
Download:
It worked fine for me (ubuntu xenial, rock64) but I was not able to ser up my keyboard layout which is French-Swiss. Any ideas how to fix this?
On recent OMV builds there is remote desktop support plugin.
Works fine with xdrp/xorg "out of the box". Smile
  Beginners Guide: Migrating to SSD rontant 18 48,418 01-19-2022, 09:30 AM
Last Post: Ellesar Dragon
Information Beginners Guide: Adding USB Storage, Linux Formatting and Permissions Ptheven 4 14,783 03-06-2021, 01:49 PM
Last Post: helpmerock
  Step by step guide PXE diskless configuration. burglar_ot 13 42,474 11-01-2020, 11:26 PM
Last Post: michael.gruner
Star Debian Stretch Minimal complete install LXDE Rafal 0 3,736 03-15-2019, 07:59 AM
Last Post: Rafal
Thumbs Up A guide for how I made RetroPie, RetroArch, and EmulationStation Work on the Rock64 Mrfixit2001 4 18,882 12-17-2018, 03:52 AM
Last Post: va88
  Install Standard Debian (upstream) Catbot 1 7,812 08-24-2018, 05:34 PM
Information Guide - Raid Array (Raid 0) Ptheven 0 5,684 10-07-2017, 09:22 AM
Last Post: Ptheven
Information Guide - Setting up a NFS Share Ptheven 0 6,471 09-26-2017, 04:44 AM
Last Post: Ptheven
  Guide - Setting up a SMB(Windows) file server Ptheven 0 13,907 08-21-2017, 08:54 AM
Last Post: Ptheven
Information Beginners Guide: Locating your board, connecting to it. Ptheven 5 19,042 08-21-2017, 04:12 AM
Last Post: Ptheven
