Install Standard Debian (upstream)
Greetings everybody,
Today on my quest to enable the rock64 for my purposes I had just one goal:
Install upstream debian testing (buster) without any customizations.
Sadly I did not achieve this goal fully; However I believe I got extremely close. See below for the one bugreport I opened to have the last piece upstreamed.
So here are the steps from an existing debian system running on the board (mostly in pseudo-code because the difficulty level isn't novice):
0. Install U-Boot to SPI Flash
- https://github.com/ayufan-rock64/linux-u-boot/releases
1. Partition (e)MMC
 - 100MiB EFI partition (fat)
 - 1GiB boot partition (ext4)
 - 57GiB rootfs partition (f2fs)
2. mount filesystems
 - rootfs: /mnt
 - boot: /mnt/boot
 - efi: /mnt/boot/efi
3. bootstrap debian
 - debootstrap --arch=arm64 --variant=minbase buster /mnt http://deb/debian.org/debian
4. mount additional filesystems
 - mount -vt sysfs sysfs /mnt/sys
 - mount -vt proc proc /mnt/proc
 - mount --bind /dev /mnt/dev
 - mount --bind /dev/pts /mnt/dev/pts
 - mount --make-rslave /mnt/dev
 - mount --make-rslave /mnt/dev/pts
5. install additional software
- tasksel ssh-server (this is a little messy in a chroot)
- apt install linux-image-arm64 grub-efi-arm64
- apt install ifupdown locales
6. configure system
 - /etc/initramfs-tools/modules: f2fs
 - /etc/default/grub: GRUB_CMDLINE_LINUX="earlycon=uart8250,mmio32,0xff130000 console=ttyS2,1500000"
 - /etc/default/grub: if [ -z "$GRUB_DEVICE_UUID" ] && [ -n "$GRUB_DEVICE" ]; then GRUB_DEVICE_UUID=`blkid -s UUID -o value "$GRUB_DEVICE"`; fi
 - dpkg-reconfigure locales
 - dpkg-reconfigure tzdata
 - /etc/network/interfaces: auto eth0
 - /etc/network/interfaces: iface eth0 inet dhcp
 - /etc/network/interfaces: iface eth0 inet6 auto
7. make it bootable
 - update-initramfs -u
 - grub-install --target=arm64-efi --removable
 - update-grub
 - copy /usr/lib/linux-image-4.17.0-1-arm64/rockchip/rk3328-rock64.dtb to /boot/efi/rockchip/rk3328-rock64.dtb
At this point the system could be rebooted and should automagically start up through grub.However one piece is still missing:
When the DTB gets updated with a new debian kernel, the copy on the EFI partition has to be updated as well.
For this we use the debian specific flash-kernel application by adding the following entry to /etc/flash-kernel/db:
Machine: Pine64 Rock64
Boot-DTB-Path: /boot/efi/rockchip/rk3328-rock64.dtb
DTB-Id: rockchip/rk3328-rock64.dtb
This bit of magic makes sure that on every kernel update the rk3328-rock64.dtb gets copied to the EFI partition where U-Boot can load it *before* executing grub.
This is necessary because grub-mkconfig can not guess where the devicetree is and how it is called.
I have opened a bugreport against debian to have this piece included upstream: https://bugs.debian.org/cgi-bin/bugrepor...bug=906696
I strongly believe that debian-installer could be used from a usb drive to install debian. It would be much easier than the instructions above, especially when a preseed file is used for automation.
(08-19-2018, 02:26 PM)Catbot Wrote: Greetings everybody,
1. Partition (e)MMC
 - rootfs: /mnt
 - boot: /mnt/boot
3. bootstrap debian
6. configure system
7. make it bootable
 - update-grub
Thanks, we have same goal that eventually should able to use standard distribution build from Debian, Ubuntu, Opensuse and others.
Information Manual: Howto cross-compile Upstream U-Boot for rock64 rock7 3 15,214 04-15-2020, 05:09 PM
Last Post: rock7
Star Debian Stretch Minimal complete install LXDE Rafal 0 4,973 03-15-2019, 07:59 AM
Last Post: Rafal
  Guide - XRDP - Debian Stretch / Ubuntu Xenial / OMV S3phi40T 3 18,842 05-05-2018, 06:08 AM
Last Post: S3phi40T
