ROCK64 STEREO AUDIO DAC ADD-ON BOARD
Which pins does the DAC board use? It looks like it uses the 20 pin. Does this mean that it leaves the 40 pin GPIO pins free to use?
(02-06-2018, 10:01 AM)angelscream09 Wrote: Which pins does the DAC board use? It looks like it uses the 20 pin. Does this mean that it leaves the 40 pin GPIO pins free to use?
yes, the 40 pin GPIO pins are free to use. For more Pi2 and Pi5+ bus, DAC board schematic, you can refer to PINE64 wiki page: http://wiki.pine64.org/index.php/ROCK64_...ifications
I'm struggling to find which pins is connects to ... Could someone post a pic with the dac mounted?
Thanks in advance!
What image is better for use with the DAC? Will it work only with Volumo or other images will work too?
bin4ry, have you succeeded?
The DAC runs not synchronous to the I2s clock form the SoC/Rock64.
Which means DAC's have to drop and/or duplicate audio samples.
So do not expect quality sound, regardless which distro used.
See Thread "I2S1_MCLK".
@moris, see jumper J3, http://files.pine64.org/doc/rock64/ROCK6..._Board.pdf
Isn't that what you want?
(11-17-2018, 09:15 AM)antonv Wrote: @moris, see jumper J3, http://files.pine64.org/doc/rock64/ROCK6..._Board.pdf
J3 1-3 => asynchronous to SoC.
J3 2-3 useless so far as no MCLK on Pin 3.
Wow, indeed, I only have sound in one position of the J3 jumper, and silence in the other position (they are not labeled, but I guess the working one is 1-3).
According to the schema, MCLK should be there...
Maybe we do something wrong? Or some workaround?
  DeskPi case alternative for ROCK64 v1k699 2 13,419 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,709 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,595 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,332 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,509 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,057 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,959 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,740 11-07-2022, 05:45 PM
Last Post: olivercfc
  Audio Pot Board Questions vfr400racer 4 9,659 10-11-2022, 09:21 PM
Last Post: Roberto2020
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,099 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
