is my eMMC broken or am I wrong?
Hi
I bought one eMMC from pine64.org and it's my first time to use eMMC.
I'm not sure whether I'm doing wrong or this is broken.
What I've tried is,
1. using eMMC to microUSB adapter
I bought this. but doesn't work. my PC can't read it.
this video shows some SD card reader is not compatible with the adapter.
so maybe my one as well.
[Image: uc?export=view&id=1uOE_oc764Z4_Rkz24qpBXK22fDWDO2HF]
2. writing an Image to eMMC module according to this tutorial
I followed until step 6, but I can't see mmcblk0. only mmcblk1 shows up from 5-7 tries.
left block is a log when I followed the tutorial and right is a log I used sd card only.
I removed jumper before I type boot command.
[Image: uc?export=view&id=1Rjtj-XJhIH2s1ia0Kg0Cm-zKNj8nEvu1]
How do you think?
Thank you :-)
yeah, not sure what board you want the emmc to fit onto but the instructions you link are for a rock64 and they specifically state that the emmc must be installed in the rock64 and not an adapter.
(01-11-2018, 10:09 AM)dkryder Wrote: yeah, not sure what board you want the emmc to fit onto but the instructions you link are for a rock64 and they specifically state that the emmc must be installed in the rock64 and not an adapter.
Oh, sorry. That's two separate methods I've tried. I have rock64 4GB board. eMMC and sd card are installed on the board in the second method.
my guess is the jumper is not registering correctly, i.e however you jumper the pins is not working
(01-12-2018, 01:23 AM)dkryder Wrote: my guess is the jumper is not registering correctly, i.e however you jumper the pins is not working
I tried with jumper pin and jumper wire. both didn't work. I checked continuity of it with a multimeter (pic below is just for showing jumper. I installed eMMC and sd card when I test)
hmm... Is there anyway that I can figure out this eMMC is working properly? So that I can decide to buy emmc to usb adapter from pine64.org or buy new eMMC?
[Image: uc?export=view&id=11AAAQYF7PuGLnR4S9qciled47RjYLi5Z]
you could try this. but since this thread is in pine64 category why not create a new thread in rock64 category and link new infos there plus a link to this thread for historical reference.
https://forum.pine64.org/showthread.php?...droid+tool
even if you do not want android it will see if emmc works
you could also give this a try
http://files.pine64.org/doc/rock64/guide...o_eMMC.pdf
(01-12-2018, 08:17 AM)dkryder Wrote: you could try this. but since this thread is in pine64 category why not create a new thread in rock64 category and link new infos there plus a link to this thread for historical reference.
Thank you :-) I'll try it. (btw, I think it's in general category isn't it?)
yes, but it is pine64 top category which is a category actually started when the pine64 was the only board. feel free to place your posts where ever you want it. historically it has been considered by many to find the most specific section/category related to you question hence my suggestion to use rock64 since your issue concerned the rock64. i think there is even a general section sub-category in the rock64 section.
moved to this thread
self answer : it was OS image bug. I used ayufan's OS ver 0.6.5. it's disappeared since ver 0.6.6.
[url=https://forum.pine64.org/showthread.php?tid=5622][/url]
  eMMC empty? bluedemon382 0 2,595 07-19-2023, 06:29 AM
Last Post: bluedemon382
  USB adapter to eMMC module not recognized danril 0 3,308 11-25-2022, 04:16 AM
Last Post: danril
  wrong launguage install chadace 1 6,486 06-08-2020, 08:31 PM
Last Post: chadace
  How to flash Focal Gnome to EMMC cyphr3x 0 3,828 06-05-2020, 02:06 PM
Last Post: cyphr3x
  No signs of life - what am I doing wrong? bratoff 12 30,779 04-26-2020, 03:50 PM
Last Post: bratoff
  How to boot from the SD card and install to eMMC? ravanh 2 10,488 03-18-2020, 09:42 AM
  How to check eMMC? ame 5 13,123 01-08-2019, 04:31 PM
Last Post: ame
  eMMC card on adapter Malmgren 8 19,172 03-20-2018, 11:14 AM
Last Post: Malmgren
  Rock64 OS eMMC boot ProfessionalDreamer 2 8,169 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
Star ROCK64 emmc Diogenes08 2 8,497 12-29-2017, 02:53 PM
Last Post: Diogenes08
