Booting from eMMC
I just received my Pine64-LTS version with 64GB eMMC. I am having major issues trying to boot from the emmc.
I have tried the following
Downloaded the images from
https://github.com/ayufan-pine64/linux-build/releases
mainly
jessie-minimal-pine64-0.7.19-118.img.xz and xenial-minimal-pine64-bspkernel-0.7.19-118.img.xz
1. I then wrote the image to SD card and booted the Pine, which is fine.
2. Followed the instruction to
sudo ./pine64_update_kernel.sh 0.7.19
sudo ./pine64_update_uboot.sh 0.7.19
sudo ./pine64_update_package.sh 0.7.19
3. executed sudo ./pine64_install........to_emmc.sh xenial-minimal 0.7.19
4. Tried setting the following
emmc_compat=on
emmc_compat=150mhz
emmc_compat=200mhz
5. removed the SD
6 booted with eMMC
I get nothing.
Does the boot take very long as compared to SD (i have left it for few hours)? I get nothing.
I have also tried to burn the above image directly to the emmc without any luck.
Is there something I am missing?
Sailesh
it looks like you are using the wrong image. lts boards have to use pine64 lts/sopine, or pine64/sopine and the lts or sopine will be in the image name. because of the memory on the lts they have to use the same image as sopine modules.
(01-08-2018, 01:09 PM)saileshrajk Wrote: Hi,
mainly
emmc_compat=on
emmc_compat=150mhz
emmc_compat=200mhz
5. removed the SD
6 booted with eMMC
I get nothing.
Sailesh
Did you try a reboot beetwen point 2 and 3?
2. Update SD
2.5 Reboot
3. Install to eMMC
Thanks all,
I got the sopine image and it worked. Smile
Sailesh
Any idea where to find password to login jessie-minimal?
regards.
(06-13-2018, 07:11 AM)ccaramel Wrote: Hi,
regards.
My guess is pine64/pine64 for the LTS and SOPine
regards.
Yeah!! many thanks
regards.
Yeah!! many thanks
But having same problem of booting from emmc: it's not working.
Although log indicate that pine64_install_to_emmc.sh script uses the right sopine image:
Using https://github.com/ayufan-pine64/linux-build/releases/download/0.7.19/xenial-minimal-sopine-bspkernel-0.7.19-118.img.xz
Is someone got any idea?
I have FreeBSD booting from eMMC.. needed to patch the driver a bit to make it work stable.
Still not 100% because I need to implement 2 more clocks to get more the 52Mhz out of it.
I will post an image shortly that can boot from PXE, SD or eMMC.
mainly
emmc_compat=on
emmc_compat=150mhz
emmc_compat=200mhz
5. removed the SD
6 booted with eMMC
I get nothing.
Sailesh
2. Update SD
2.5 Reboot
3. Install to eMMC
I just bought an LTS with 32G eMMC.
I also bought the "USB adapter for eMMc Module" for $4.99
(It allows you to burn an eMMc on your desktop computer just like an SD card)
I burned my eMMc using this, then put eMMc in the LTS.
Booted first time.
Ian James
Sincerely,
Ian James
  eMMC fail in 2% of flashing barucha 10 22,089 12-14-2020, 06:51 AM
Last Post: Little_Johnny
  Problem with EMMC bootup and detection khantheengr 6 13,123 12-10-2020, 05:26 PM
Last Post: poVoq
  SoPine eMMC compatibility Terra854 4 11,671 02-20-2020, 07:52 PM
Last Post: mcrognale
  LTS can't see eMMC devices 1291 4 11,398 02-20-2020, 07:43 PM
  Pine64 LTS Not booting krisclarkdev 2 6,132 05-13-2018, 10:22 PM
Last Post: krisclarkdev
  Pine A64-LTS not booting williamcolls 1 4,537 03-29-2018, 01:09 PM
Last Post: dkryder
  EMMC cards in Pine64 store stephen fleming 16 54,728 12-26-2017, 12:19 PM
