Pine64 LTS Not booting
Hi all, I just received my Pine64 LTS in the mail today and loaded Diet Pi on an SD Card quickly to find out that it's not booting.
* Power is the provided barrel connector that I purchased
* SD Card is a San Disc 32 GB
* eMCC from plugged in, purchased at the same time as my Pine64
* USB Keyboard plugged in
* USB Mouse plugged in
I checked my DHCP Lease table and it doesn't look like it's powering up and getting an address.  I then took the SD Card out and put it in my Model B Pine64 and it boots right up without issue.
I also noticed that my USB Keyboard back light was on and the mouse was powered up too.
I then put the SD Card back into the LTS and removed parts one at a time in this order.
* eMCC
* Mouse
* Keyboard
* HDMI
And it is still not booting.
I've tried both Diet Pi and Xubuntu with the same results.  I'm starting to think my Pine64 was DOA.  Thoughts?
tyia,
Kris
(05-12-2018, 03:04 PM)krisclarkdev Wrote: I've tried both Diet Pi and Xubuntu with the same results.  I'm starting to think my Pine64 was DOA.  Thoughts?
Dies DietPi support the Pine64 LTS? I know it supports the Pine64, but due to some changes in the LTS board maybe it won't work on that? Can you try this image - as according to the wiki the sopine images are the correct images to use on the pine64 LTS.
https://github.com/ayufan-pine64/linux-b...118.img.xz
I figured out my issue shortly after posting this. I was using Pine64 images but needed to be using a SOPINE image.
Question How to connect a pine64-LTS to a serial console? zuvmajujo 1 899 04-02-2023, 05:09 PM
Last Post: zuvmajujo
  Pine64 LTS won't boot zuvmajujo 1 874 04-02-2023, 04:59 PM
  Has anyone gotten "reset" to work in U-Boot for Pine64? Pine 1 3,349 04-19-2021, 12:55 PM
Last Post: Pine
  power usage for Pine64 LTS + Screen Little_Johnny 1 2,892 02-17-2021, 07:19 PM
Last Post: Little_Johnny
  Booting from eMMC saileshrajk 12 19,265 02-16-2021, 01:02 PM
Last Post: IanJames
  Pine64 LTS GbE Problem scchoi 1 3,979 06-20-2020, 12:39 PM
  Selling my Pine64 2gb LTS with a bunch of accessories poponon 0 2,559 08-08-2019, 09:01 PM
Last Post: poponon
  change the charge LED indicator to Mode B on Pine64 LTS JTX 0 2,497 04-12-2019, 06:34 PM
Last Post: JTX
  Pine64 LTS Boot Media order Akash Gajjar 1 3,292 07-22-2018, 05:29 PM
  Pine64 LTS - DOA harcrow 8 8,273 03-30-2018, 02:13 PM
Last Post: davidgs
