Making a Ubuntu Server image for SD Card
Hi all!
So I finally got my board in the mail and I starting to experiment with it. I loaded up the premade Arch Linux Distribution and played around with it for a while, but now I'd like to start trying to load the board with a Ubuntu Server 14.04 image, since I plan to use it as a lightweight headless server. I am not planning to use any GPU functions, so I don't care about lack of hardware GPU acceleration.
The question that I have is essentially this, how can I take the Ubuntu Server ARM images provided here (and which arm image do I need): http://cdimage.ubuntu.com/ubuntu-core/re...4/release/ along with the current Linux kernel builds provided here: https://www.stdin.xyz/downloads/people/l...64-images/ to create a bootable SD card to run this on my Pine 64? For reference, I have the Pine A64+ 1GB board.
Thanks!
insignia96
PS: I am only a CS undergrad, so I am still learning a lot about different architectures and this is my first foray into low level ARM boards. In other words, sorry if this seems like a dumb question!
Use longsleep's latest Xenial image and you have all you need except of a kernel you can trust in Wink
All you need is here: http://blog.antani.co/pine64-install-ubu...04-xenial/
Thanks for the info, I will try that image out! Smile
Out of curiosity though, what kind of process would I have to go through to "roll my own" images for this board? I can imagine that it's a relatively complex process, but is there a good rundown of how to get started?
EDIT: For future reference for those with a similar question, this is what I was looking for.
https://github.com/longsleep/build-pine64-image
  Gentoo Linux test image xalius 23 73,723 01-28-2019, 11:05 PM
Last Post: necrose99
  Issues with both Deb and Ubuntu germanshep 0 4,473 08-28-2018, 05:47 PM
Last Post: germanshep
  need help, looking to setup NAS server over OpenWRT subbu 0 4,152 05-26-2018, 07:48 AM
Last Post: subbu
  Making a DVD Server (including burning) using Rock64 Ron Piggott 1 5,596 04-11-2018, 08:33 AM
Last Post: dkryder
  Linux Web Server OS harcrow 2 9,256 01-30-2018, 10:26 AM
Last Post: Rustproof
Rainbow automatic proxy server Brainmore 0 3,665 01-10-2018, 10:56 PM
Last Post: Brainmore
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 17,183 11-02-2017, 06:34 AM
Last Post: XaRz
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 45,415 10-07-2017, 10:06 PM
Last Post: speedro86
  eta linux image?? firosiro 1 6,785 08-03-2017, 10:05 PM
Last Post: pfeerick
  Flashing SD card over USB ccben 5 15,049 07-25-2017, 10:11 PM
Last Post: ccben
