Hardware-Bugs: No HDMI->DVI-Output / Crashes upon Ethernet
hey folks,
yesterday I finally received my 2GB-Pine. So far, so nice. Since then I was able to boot RemixOS, but experienced some problems. First, the video output works with a HDMI2HDMI-cable connected to my TV, but not with a HDMI2DVI-cable which I need for my monitor. I checked the cable of course, it works perfectly with my Raspberry. Does anyone have a clue how to force the display output to work?
I'm also having trouble with the ethernet port, but I noticed that I'm not alone with this issue. The Pine crashes right after I plugged in an ethernet cable. So someone wrote about a possible workaround for this issue, but I couldn't find in on the forums. Can anyone provide me with a link? Thanks in advance!
btw: I noticed that some of you are still struggling to find the right power adapters and cables. I used an iPhone charger combined with the white micro-usb cable which came with my amazon kindle.
RemixOS has been installed via PhoenixCard installer. Just make sure that you checked the "startup"-box not the "product" one before you install the IMG-file.
(04-02-2016, 03:07 AM)Xyntec Wrote: not with a HDMI2DVI-cable
Known problem for H3, A83T and A64 when using BSP kernel. With kernel 3.4 you modify sysconfig stuff like this, for A64 it might require device tree modifications. You better ask in Linux Developer forum since longsleep might be the only here in this forum that has ever looked into the .dts deep enough Wink
Thanks mate!
Gna, OK. But at least the problem is being known. Smile
But I guess there ain't a pre-compiled img file I just need to write on a card, right?
The 2gb pine is currently having issues with a kernel panic happening with an ethernet cord plugged in. We've been talking about it over here: http://forum.pine64.org/showthread.php?tid=376
Pages 4-7 contain the most relevant info. Longsleep thinks he has an idea on what it may be.
  Hdmi To VGA pine771 7 15,791 10-09-2016, 12:17 PM
Last Post: Zoidiano0
  hardware installation video tutorial top3b 2 6,794 07-29-2016, 10:52 PM
Last Post: blackt1ger
  output on LCD screen Rigor_M 1 5,509 07-18-2016, 12:41 PM
Last Post: Rigor_M
  USB NIC / Ethernet thegroverest 1 4,959 07-01-2016, 01:41 PM
Last Post: dkryder
  HDMI to RCA for connecting CRT type TV desai_amogh 1 5,956 05-22-2016, 08:54 AM
  Few Hardware Questions dav3yb 3 10,119 03-20-2016, 11:06 AM
  Hardware Source enoCeniP 27 61,743 02-27-2016, 01:11 PM
  Hardware pins Tremoneck 8 20,982 02-17-2016, 06:23 AM
  Power over Ethernet (PoE) WLR 1 8,561 02-10-2016, 07:14 PM
  HDMI to VGA adapter trumad 7 18,767 01-29-2016, 04:55 PM
