hardware installation video tutorial
Hi mates,
I need an help to understand how to connect the camera and LCD cable to the board connectors, is there any video tutorial?
How should i have to release the connector and then put in the flat cable?
Thank you in advance
Regards Smile Smile
hi, the connector on the PineA64 is very fragile and requies a significant finesse, as I think I've told you before, top3b.
BE CAREFUL
The trick is to lift up (gently using your finger-nail, no tools) on the black bar VERY carefully. Then tuck the end of the cable into the connector squarely with the contact pads down...
... then close the black bar, again being careful not to damage the bar, nor the cable, nor the pins !
All the connectors work the same way...
feel free to join us on chat at irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697
marcus
Mark,
Which is pin 1 on the board for the camera connection.  I see a "o" but it looks like a via.   Or maybe the android image shipped in the box (I got a 64 gb sd card from you guys) doesn't yet work with the camera?  The cable is well marked.
  Hardware-Bugs: No HDMI->DVI-Output / Crashes upon Ethernet Xyntec 3 8,721 04-02-2016, 09:42 AM
Last Post: DaveKram
  Few Hardware Questions dav3yb 3 10,016 03-20-2016, 11:06 AM
  Hardware Source enoCeniP 27 61,018 02-27-2016, 01:11 PM
  Hardware pins Tremoneck 8 20,771 02-17-2016, 06:23 AM
  Hardware Decoding Tuxkey 3 10,409 01-27-2016, 03:09 PM
  H.264 Video Encoding? bigmacattack 1 6,602 12-13-2015, 03:20 AM
