Using ODROID 16x2 LCD kit on Rock64
Wink
I'm trying to port the ODROID 16x2 LCD kit to the Rock64. The LCD functions with GPIO pins. However, since GPIO on the ODROID and the Rock64 differ, I'm trying to port the pin system. The GPIO shield for the ODROID LCD is unnecessary for porting this since the P2 block on the LCD board itself has its own pin scheme. There are only 16 pins in this scheme (of which only 10 are used). See pictures below for layout details...
The P2 block on the LCD shield. This block directly powers the LCD. GPIO input shield is a different set of pins.
[Image: 5qsjQZDJndm7t4n0fktAwrzQaAezqEUvZ1ZvJh0C...80-h292-no]
The entire shield (notice the stacked boards). The pins on the green board directly control the LCD. The pin input information for the 16 pins on the green board are in the above image. "X" indicates the pin serves no purpose.
[Image: 2cl3lCwwyVB0sT-FlPvePeatVbgVB-f6pPYb5Yfl...80-h720-no]
Would this involve modifying the code for the ODROID LCD controller program? The code and installation instructions for the ODROID-C (I assume any C model ODROID board) can be found here (https://wiki.odroid.com/accessory/displa...ld/c/start).
I'm new to GPIO so any clarification regarding my understanding of the pin system are appreciated.
Thanks.
  Are HW design files available for ROCK64? irenek 3 4,772 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 331 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,068 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 624 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,229 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,746 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,525 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,626 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,522 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,046 09-28-2021, 03:07 PM
Last Post: TRS-80
