LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
#51
(11-17-2017, 01:05 PM)Mrfixit2001 Wrote: @Raybuntu - when I try to compile I end up with "./libxml/encoding.h:29:19: fatal error: iconv.h: no such file or directory", #include <icon.v>
Obviously you can compile fine so I'm wondering if you have any tips or thoughts? I'm using cygwin64 on my win7 pc to compile. It runs for a good couple hours before it terminates.
Cygwin or any windows linux subsystem is not supported. Try to use either docker (there is a docker file) or s Ubuntu 16.04 Virtual maschine.
@Raybuntu - I setup virtualbox and propped up ubuntu 16.04 VM. Gets much further but errors with:
Makefile:9: recipe for target 'release' failed
make: *** [release] Error 2
This occurs after: build.LibreELEC-ROCK64.arm-9.0-devel/binutils-2.29/gold/incremental.cc
If you have any advice I'd appreciate it.
Just restart the build process and pastebin more of the output otherwise there is no way to tell what's broken. Btw building from scratch LibreELEC master breaks from time to time.
https://github.com/Raybuntu/LibreELEC.tv.../rb-leia17
This one could be a little bit more unstable.
(11-24-2017, 08:11 AM)Raybuntu Wrote: https://github.com/Raybuntu/LibreELEC.tv.../rb-leia17
For some reason I have sound crackling / stuttering using SPDIF (audio POT) which were not present on the previous build.
@Raybuntu - just wondering how difficult it would be to "downgrade" your source code back to the latest stable release of KODI? Seems like the newest build doesn't work with emulationstation or retroarch (both just close immediately and restart kodi). I'm attributing that to the newest kodi build being incompatible, but I welcome your feedback. I was wondering if it might be as easy as update the packages with the older kodi version numbers and recompiling? And do you think this would resolve the emulationstation and retroarch problem?
You can just drop the previous tar in the /storage/. update folder and reboot.
Will HDR support be possible eventually?
Thanks for the quick reply. 3 questions... Are the issues in emulationstation and retroarch non existent in the previous version of KODI? And by using the previous tar don't I loose any of your updates to the rest of the packages and add ons? And which previous tar, considering there's no ROCK64 release for your krypton revision?
(11-25-2017, 05:38 PM)Mrfixit2001 Wrote: Thanks for the quick reply. 3 questions... Are the issues in emulationstation and retroarch non existent in the previous version of KODI? And by using the previous tar don't I loose any of your updates to the rest of the packages and add ons? And which previous tar, considering there's no ROCK64 release for your krypton revision?
Ahh ok you wanna use Krypton. No retroplayer is not supported in Krypton. You can loose addon updates respectively you could be forced to downgrade your addons.
  Libreelec nfs shares nberg@xs4all.nl 0 677 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 1,303 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,870 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,695 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,418 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,095 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,152 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,681 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,033 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,138 11-16-2019, 12:17 PM
Last Post: dkebler
