LibreELEC Krypton/Leia/Agile 64bit kernel 32bit libs
Any news on Amazon and Netflix ? Smile
(10-11-2017, 08:07 AM)Luke Wrote: Any news on Amazon and Netflix ? Smile
Not yet ready. @Kwiboo is currently working on the LE9 branch.
https://github.com/Raybuntu/LibreELEC.tv.../rb-leia15
(11-10-2017, 02:07 AM)Raybuntu Wrote: https://github.com/Raybuntu/LibreELEC.tv.../rb-leia15
Nice Smile Compatible with the RockBox or just the Rock64 ?
That build will only work on Rock64. I haven't had a time to unpack my Rockbox yet.
Also I had to revert an u-boot commit by kwibbo otherwise it wouldn't boot for me on Rock64 from SD card. I have no emmc to test so it might be possible that it fails to boot from emmc.
I have tested HW decoding, Netflix, Amazon VOD and Dazn. Netflix is not that smooth 720p and up yet.
Ok, no worries. Will test it out monday (currently away) and offer feedback. Netflix and Amazon VOD can be installed from the repo that is available on the image ?
Not directly. From my repo (RB Addons) you can install a repo called Kodinerds. Once you have that you can install the Netflix repo. This comes directly from the NF addon authors and is always up-to-date.
Amazon VOD addon is also in a seperate repo: Sandmann79s Repository
Those are always maintained by the addon authors.
In Kodinerds Repo there a lot of only legal usefull Video, Musik Addons that are more recent than those in official Kodi.tv Repo.
Beware that those DRM protected video's only play if you install widevine which is proprietary and therefor not included in my builds. Soon there will be an Addon to handle widevine download automatically in official kodi.tv repo.
You can use milhouse script to install it just ssh to your box:
curl -Ls http://nmacleod.com/public/libreelec/getwidevine.sh | bash
Thank you for the explanation!
i put rb-leia15 to emmc but usb are not working at all Sad
so i cant test (i plugged a mouse and a with airmouse https://www.pine64.org/?product=pine64-a...h-keyboard)
Edit:
i resinstalled stretch then i reflashed and it seems to work, will test later Smile
eMMC boots successfully.
UK HDTV poor decoding.
UK SDTV decoding is fine.
  Libreelec nfs shares nberg@xs4all.nl 0 683 11-11-2022, 01:18 PM
Last Post: nberg@xs4all.nl
  Linux 5.15 Kernel - openSuse mark1250 0 1,309 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,932 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian kernel stuck at 4.4.167 Enig123 5 5,726 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 12,467 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 4,114 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 7,186 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 4,710 03-02-2020, 04:18 PM
Last Post: gabrielfin
  need a dts file to set some pins as pulldown interrupts in kernel using a DTO dkebler 0 2,042 02-05-2020, 10:58 PM
Last Post: dkebler
  Any advantages to using the mainline kernel dkebler 0 2,143 11-16-2019, 12:17 PM
Last Post: dkebler
