solved: ROCK64 Stereo Audio POT-Board anyone having success getting sound?
Thumbs Up
Hello everyone,
Last Monday I received my Rock64 including the ES9023 Audio POT-Board. Till now I don't have any success getting audio out of this board. aplay -l lists 3 cards. Card 1 is i2s device. I tried speaker-test, aplay  and mpd but and don't get any sound or error.
For example:
speaker-test -c2 -D hw:1,0
claims to play noise but nothing is heard. Audio-Pot board is connected to a small Class-D amplifier with speakers. I am using ayufan's debian stretch minimal image.
Did anyone got any sound out of the Audio-POT-Board? If yes: Which image/settings where used?
Thanx for your help.
No luck so far but I'm certainly not a linux guru. Installed Amarok, tried to see if I could set the output to the optical SPDIF but nothing works.  Haven't tried it on Xenial. Been playing with Debian LXDE load. I hope the answer isn't that until a volumio load is made the DAC won't be operational.
More testing, same results. Can't get audio out via audio jack, RCA connections on DAC, optical on DAC or HDMI. I spent some time reading Pine64 sound threads. Seems it took some tweaking in order to get audio to work. People referred to mixer settings in alsamixer. Fired that up, "this device has no settings" for all three of the audio outputs available. I'll keep digging but if anyone has definitive answer on whether I should be able to put my headphones on, fire up a favorite .flac file and listen to music while I'm tinkering I'd like to know. If it's dependent upon kernel/package stuff out of my control I understand and know there are other priorities. Just need to know if I'm banging my head against the wall and could save time by just waiting for the experts to weigh in. Thanks.
Tried Xenial Mate, stock Debian - same thing on both. Haven't tried Android but will.
you might want to search the chat logs to see if there has been any meaningful discussions on the status of the board. the time i spent reading logs during the build up to first sales did not have any info i can remember. but, in some cases those logs have discussions about stuff that can not be found elsewhere.
Will do. In the meantime, Android sound works on the stock build. I mainly wanted to prove the DAC was working so connected RCA cables to my receiver. "It's alive!" Didn't check the optical, I will eventually but was glad to hear output from the RCA jacks. While music was playing I plugged in headphones to the audio jack. The RCA output wasn't muted but I did hear sound from the headphones so that jack is operational too. I remember reading something about that being an issue. For now, I'm thinking the linux builders haven't gotten to includiing the audio pieces yet. I'll keep playing.
The latest 0.5.x does output sound.
Kwiboo on IRC:
RockyBoulder Xalius: the audio POT board should work including spdif, but at the moment there are some limitations on the i2s bus and the J3 jumper needs to be changes to use 50M OSC
[7:02 PM]
I need to write a simple codec driver for i2s that allows correct sample rates, channels and sets mclk that works with es9023 for full function
[7:09 PM]
RockyBoulder APP Kwiboo: 50 M OSC? There is none included, right? Do you can recommend one? I don't have one.
[7:15 PM]
Kwiboo APP RockyBoulder you should only need to change a jumper on the board, check https://www.pine64.org/wp-content/uploads/2017/06/ROCK64_audio_board_bottom.jpg (50kB)
in the middle 50M and MCLK it need to connect 50M and the middle pin instead of the middle and MCLK
[7:19 PM]
RockyBoulder APP Kwiboo: Thank you I checked the schmatics and found that the OSC is onboard. Thought i had to connect it through this white header. Changed j3 to use the osc and got sound with speaker-test -c2 -D hw:1,0 Now to more testing. Thank you!
[7:22 PM]
Kwiboo APP at the moment it is limited to up to 96khz and not 192khz because that is the limit of the acodec that is used for the on-board a/v jack
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
Thanx to ayufan and Kwiboo audio pot is now useable (some limit).
Hardware volume mixer is not available at the moment (don't now if this will change/ is even available).
Therefore software volume mixer is an option.
This is what I use if aynone is interessted (copy to /etc/asound.conf):
pcm.!default {
   type             plug
   slave.pcm       "rock_audio_pot"
pcm.rock_audio_pot {
   type            softvol
   slave {
       pcm         "hw:1"
   control {
       name        "Master"
       card        0
How good is the audio quality?
Also wondering if it only works on Volumio or everything like youtube, retropie...
  Are HW design files available for ROCK64? irenek 3 4,780 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 331 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,069 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 624 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,232 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,749 11-07-2022, 05:45 PM
Last Post: olivercfc
  Audio Pot Board Questions vfr400racer 4 3,123 10-11-2022, 09:21 PM
Last Post: Roberto2020
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,532 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,629 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,537 03-04-2022, 06:56 AM
Last Post: killor
