Did I brick my Pinebook?
Hello, hoping someone can help me - I got in over my head with my Pinebook settings (using Pinebook with Ubuntu Mate 16.04) and increased the size of my /boot partition by unmounting, increasing the size and remounting. The updates that were required before but couldn't complete because of lack of space worked but after a reboot, nothing comes up on the screen. Have tried to restart it in safe mode (hitting Escape button, tab button, etc when booting up). All I get is a power light and nothing on the screen. I tried loading an .img of 16.04 to an SD card in hopes it would boot from that but that didn't work either.
No response from the Pinebook support team.
Wondering if anyone can help?
Thanks,
gmoney604
(07-17-2017, 09:28 AM)gmoney604 Wrote: Hello, hoping someone can help me - I got in over my head with my Pinebook settings (using Pinebook with Ubuntu Mate 16.04) and increased the size of my /boot partition by unmounting, increasing the size and remounting. The updates that were required before but couldn't complete because of lack of space worked but after a reboot, nothing comes up on the screen. Have tried to restart it in safe mode (hitting Escape button, tab button, etc when booting up). All I get is a power light and nothing on the screen. I tried loading an .img of 16.04 to an SD card in hopes it would boot from that but that didn't work either.
Thanks,
gmoney604
There is no way to brick the Pinebook, so don't worry. Moreover, the Pinebook is meant for learning and experimenting - so this is to be expected. You may have corrupted the image; was there something of real value on this installation ? if there was do let me know.
For the time being I will assume there wasn't; download the installer utility to your main computer (please read this thread first) and get the Ubuntu Mate (eMMC) image installed onto your eMMC.
You may wish to update to the latest release version once the image is flashed:
Navigate to /usr/local/sbin
cd /usr/local/sbin
and run the following
sudo ./pine64_update_kernel.sh 0.6.2
sudo ./pine64_update_uboot.sh 0.6.2
sudo ./pine64_update_package.sh 0.6.2
Thanks,
gmoney604
cd /usr/local/sbin
Thanks Luke, I will try this - so glad to hear that I likely have not ruined it! To answer your question, nothing of value was on there, so don't mind doing a wipe.
Much appreciated.
Luke, just wanted to say thanks for the tip, that worked 100%. Appreciate it!
gmoney604
  pinebook 1080p power/barrel connector/cable cel 0 546 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,381 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,232 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,640 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,347 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,616 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,624 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,823 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,682 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,933 07-02-2020, 06:33 PM
