Simple 3d Printed Case
I designed a simple 3d printed case since there didn't seem to be one out there already. Nothing fancy but it works.
STLs available here: http://www.thingiverse.com/thing:1428977
(03-19-2016, 10:48 PM)Jkanthony Wrote: I designed a simple 3d printed case since there didn't seem to be one out there already. Nothing fancy but it works.
Wow, cool. Thanks.
If only I was not a broke college kid id love to have one of these with my name on it.  Maybe some one would like to trade for some custom para-corde made things haha.
But I like the case will you be making more patterns?
Nice one. Thanks Can I alter it ?
If only I had access to a 3d printer.
Sent from my D6653 using Tapatalk
(03-19-2016, 10:48 PM)kanthony Wrote: I designed a simple 3d printed case since there didn't seem to be one out there already. Nothing fancy but it works.
Hi!
Thanks for making this case!
As I have a M3D printer which only prints objects in size 10x10x10cm I can't print any available Pine64 case... :Big Grin
So, what do you think, would be possible to close the case and split it in half, and add some screw mounts on the left and right (longer) side of the case to connect 2 parts of the case?
Thanks! Smile
EDIT: This is what I came up with http://www.thingiverse.com/thing:1483681
(04-11-2016, 11:59 AM)vedranius Wrote: As I have a M3D printer which only prints objects in size 10x10x10cm I can't print any available Pine64 case... :Big Grin
Same problem here. M3D Micro won't cut it. The alternatives seem to be to find a local makerspace, or print it at shapeways or a similar online service. If only I could afford a laser cutter....
Cheers,
Phil
Cheers,
Phil
But what do you think of my idea that I've made? Would that work? I think it's easily printable on M3D printer...
Just got a ROBO 3D in at school. so im goting to mod this case so it has my logo on it but when I print it ill be sure to add some photos I may add some feet to it but still getting use to the software
Backer #16,783
Do you play STARBOUND? id like to find a good server
I have a Printrbot Play and this case is just a few mm from fitting in my build Volume, its 4x4x5.. I have been meaning to order the Y upgrade kit (making it 4x8x5, and heated bed) I guess this is as good an excuse as any..
Photo Weatherproof case build ltorsini 11 36,676 11-12-2024, 10:12 PM
Last Post: ltorsini
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 86,267 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 5,931 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 17,463 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 16,325 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 26,218 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 14,262 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 123,065 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 19,254 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 7,553 10-04-2016, 02:45 AM
Last Post: modmypi
