03-19-2016, 11:56 AM
Is there any word on a fix for the overscan issues experienced by me and a few other users here?
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
HDMI overscan problem
03-19-2016, 12:09 PM
(03-19-2016, 11:56 AM)Terra854 Wrote: Is there any word on a fix for the overscan issues experienced by me and a few other users here?In Android build, can not adjust screen size to adjust for over screen issue cause by new HDMi driver. The issue has been reported and will be fixed in two weeks time. The upcoming release. mostly on this week will not able to fix this issue, and the next build will.
04-08-2016, 06:07 PM
Looks like we're a bit past two weeks, so hopefully there's an update very shortly?
04-09-2016, 11:19 PM
(04-08-2016, 06:07 PM)ak_hepcat Wrote: Looks like we're a bit past two weeks, so hopefully there's an update very shortly? Yes, this issue has been dragged longer than I expected. I will meet up with Android team on Tuesday and asking for explanation. The current reason is due to Allwinner improved the HDMI driver for p60 display and causing this issue, and wait for Allwinner fixed. This issue has affected both Android and Remix build. I will try to get an answer on this week.
04-20-2016, 10:57 AM
Still no news?
04-21-2016, 09:00 PM
Please let us know of the status. Also is there any tools we could use in the mean time?
04-22-2016, 12:09 AM
04-24-2016, 06:40 PM
Wow...
04-24-2016, 07:16 PM
(This post was last modified: 04-24-2016, 07:22 PM by lenny.raposo-pine64.pro.)
have any of you tried setting things to a lower resolution such as 1280x720 if not I will post how to do it for debian/ubuntu and oyu can adapt it for arch if that's your distro of choice use pacman
sudo apt-get install fbset sudo service lightdm stop (or whatever login manager you have) sudo fbset -a -xres 1280 -yres 720 -vxres 1280 -vyres 720 sudo service lightdm start Test that mode (Linux of Course) and let me know if there is an overscan issue occuring at that resolution
If you like my work be sure to check out my site or wish to donate to the cause
Cheers
04-26-2016, 10:14 AM
I have tried the above commands, but they don't help enough. I am using a Dell 2408WFP monitor at 1920 x 1080. This is a widescreen monitor, will Full HD resolution.
The fbset application installs OK any can be used to change the frame buffer size. Stopping the lightdm service makes my screen go black (no GUI / Window Manager). I need to reset the PINE before I can do anything else. Using the above fbset command split my screen into two parts, the the RHS being a duplicate of the LHS. There were two mouse cursors! I think this was caused by the -vxres and -vyres parameters (or possibly -a). Using -xres and -yres on their own seemed to work OK. Using the command fbset -xres 1280 brought the desktop items back onto the screen (shifting the left edge of the screen to it's proper place). However, the fond size became as little larger, as the screen resolution decreased. I tried to use the -yes option to get the taskbar to appear correctly, but even with -yres 300 the taskbar was still partially off the top of the screen and there was nothing at the bottom of the screen. Hope this helps.
David Hardingham
pine64 problem reboot | ludo77 | 1 | 3,868 |
10-23-2017, 04:47 PM Last Post: tllim |
problem pine64 when reboot | ludo77 | 2 | 4,562 |
10-23-2017, 02:37 AM Last Post: Luke |
Linux TouchLCD+HDMI | sharmayogesh | 3 | 5,101 |
04-14-2017, 01:23 PM Last Post: sharmayogesh |
OpenWRT supports ARMv8 - arm64, u-boot problem? | rgdonato | 4 | 6,794 |
03-20-2017, 03:59 PM Last Post: rgdonato |
Pine64_health.sh problem | jl_678 | 3 | 6,563 |
08-26-2016, 06:08 AM Last Post: pfeerick |
HDMI 1080P | Ophir | 1 | 3,437 |
07-27-2016, 08:17 PM Last Post: Ghost |
DTS options for HDMI-DVI adapters | xalius | 0 | 1,995 |
07-07-2016, 09:57 AM Last Post: xalius |
HDMI->DVI Works "solution" | Luke | 9 | 17,115 |
05-04-2016, 12:40 PM Last Post: Luke |
HDMI Overscan / Underscan | Dygaer | 1 | 3,735 |
04-28-2016, 07:40 AM Last Post: dhardingham |
