problem pine64 when reboot
I have a problem with my pine64: I used the image xenial-pine64-bspkernel-20161218-1.img or the image debian base to make me a server because I do not need GUI.
when I restart every time after an update (sudo reboot), I end up with a black screen (no signal).
I think the pine64 does not have bootloading.
while if i use debian mate i can do as much sudo reboot i still have the login.
Please help me
well the xenial has a date of 12-18-2016. nearly a year old so first i would suggest a newer xenial image . the debian you list no date, but again , make sure you are using a new image. that is where i think you need to start on this screen problem.
(10-23-2017, 12:21 AM)dkryder Wrote: well the xenial has a date of 12-18-2016. nearly a year old so first i would suggest a newer xenial image . the debian you list no date, but again , make sure you are using a new image.  that is where i think you need to start on this screen problem.
Yea, for starters try one of the newer images. ayufan has an OS image selection which includes debian and ubuntu
  Programming languages support under PINE64 baryluk 6 20,752 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,700 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,351 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,693 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,161 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,510 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,992 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,657 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,698 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,297 10-26-2017, 05:51 PM
Last Post: gregjo
