HDMI Overscan / Underscan
Currently the screen clips off edges of the console. Is there a way that I can change the over scan setting in the /boot/uEnv.txt file? The Raspberry Pi has something like this with their /boot/config.txt file using the following settings.
These are the one's that I would be interested in using with the uEnv.txt file.
  • DISABLE_OVERSCAN
    Set to 1 to disable overscan.
  • OVERSCAN_LEFT
    Specifies the number of pixels to skip on the left edge of the screen. Increase this value if the text flows off the left edge of the screen; decrease it if there's a black border between the left edge of the screen and the text.
  • OVERSCAN_RIGHT
    Specifies the number of pixels to skip on the right edge of the screen.
  • OVERSCAN_TOP
    Specifies the number of pixels to skip on the top edge of the screen.
  • OVERSCAN_BOTTOM
    Specifies the number of pixels to skip on the bottom edge of the screen.
  • FRAMEBUFFER_WIDTH
    Specifies the console framebuffer width in pixels. The default is the display width minus the total horizontal overscan.
[Image: IMG_1080.JPG]
[Image: IMG_1081.JPG]
Paramedic & Programmer.
Ex-Chief of Operations, WLVAC.
It is also possible to change the overscan settings on-the-fly when using a Raspberry PI. There is a small C program that writes directly to the VideoCore GPU, to control the overscan settings - https://github.com/ukscone/set_overscan
This is what we need for the PINE64.
David Hardingham
  Linux TouchLCD+HDMI sharmayogesh 3 5,069 04-14-2017, 01:23 PM
Last Post: sharmayogesh
  HDMI 1080P Ophir 1 3,403 07-27-2016, 08:17 PM
Last Post: Ghost
  DTS options for HDMI-DVI adapters xalius 0 1,989 07-07-2016, 09:57 AM
Last Post: xalius
  HDMI overscan problem Terra854 10 14,430 05-30-2016, 10:12 PM
Last Post: gdjsky01
  HDMI->DVI Works "solution" Luke 9 17,041 05-04-2016, 12:40 PM
Last Post: Luke
