Q4OS WiFi Dongle not working
I have a Pine A64+ 2GB (if it matters) running Q4OS on a SanDisk 32gb Class U3 MicroSD card (equivalent to Class 30).
I also have a RTL8188 WiFi dongle which did not work on Ubuntu, worked OK on Raspbian (for BPi) and worked smoothly on Debian.
This seems to work now on Q4OS, but when I connect to my network and specify the password, the WiFi Connected icon shows up, the text says it's "active," and I cannot acess the Internet.
Any help is, well, helpful!   Big Grin
-Tom's Piano
I am having same problem with q4os and rt5370 shows signal and connected. In terminal type sudo wpa_cli status and has ip but I unable to connect with browser.
@cheezmeister
You may need to comment out the line 'iface wlan1 inet manual' in '/etc/network/interfaces' file, so it will look like:
#iface wlan1 inet manual
Reboot and try to connect again.
Update
 My issue was managed wlan0 was only local no internet. I comment out all ect/network/interfaces and create unmanaged wlan0 connection working fine now.
Information Howto: OctoPrint Working on Pine 64 chaos_actual125 22 71,307 07-11-2021, 04:13 AM
Last Post: zer0sig
  Captive portal at school not working on the Pinebook pro WilliamZieg 2 8,327 02-06-2020, 10:41 PM
Last Post: xmixahlx
Big Grin Q4OS add storage drive simplexdan 1 4,829 05-31-2017, 08:37 AM
Last Post: Luke
  Wifi connect through terminal? cheezmeister 0 3,569 04-02-2017, 09:44 AM
Last Post: cheezmeister
  HowTo working with MPD and analog sound caragk 3 17,377 11-09-2016, 08:44 AM
Last Post: jkmooney
Exclamation JAVA App. not working correct wrongway 0 3,782 09-14-2016, 11:14 AM
Last Post: wrongway
  Anyone got jackd working? jkmooney 4 10,432 08-27-2016, 08:18 AM
Last Post: pfeerick
  Bringing up wifi dongle m16bishop 2 7,219 07-04-2016, 03:24 PM
Last Post: m16bishop
  Internet not working properly cezar.suteu@gmail.com 2 7,208 06-17-2016, 01:12 AM
Last Post: cezar.suteu@gmail.com
  wget not working? slerched 3 9,495 06-01-2016, 08:15 AM
Last Post: slerched
