Bringing up wifi dongle
hi,
I don't have a wifi BTmodule so I am trying to bring up a wifi dongle on my Pine64 2G device. Running with Debian.
I pulled the dongle off my raspberry pi  since I know it works.
My ethernet will come up but I can't seem to get the wifi dongle to work. No network connection at all with the dongle.
I have.
/etc/network/interfaces
# The wireless interface
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
# Disable Secondary Wireless Lan (8723bs Has Two Interfaces)
iface wlan1 inet manual
..and...
network={
ssid="Test Net Wifi"
psk="network-password"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
Any ideas on what I am missing? Do I need to update any drivers?
thanks
Mike
Can you check if you actually got a driver loaded for the dongle? Try "iwconfing" , does it show any interfaces? Try "lsmod" , does it show any modules for the dongle? lsusb , dmesg output could also give a clue....
Thank you for responding.
Here is what I am seeing with the commands you requested.
The two commands you suggested for ismod and isusb weren't recognized. The following are the iwconfig and dmesg outputs.
Thank you
Mike
eth0 no wireless connections
sith0 no wireless connections
lo no wireless connections
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.101-0-pine64-longsleep (longsleep@mose2) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #39 SMP PREEMPT Sat May 7 12:39:25 CEST 2016
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: sun50iw1p1
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s18816 r8192 d22144 u49152
[    0.000000] pcpu-alloc: s18816 r8192 d22144 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend disp.screen0_output_mode=720p60 earlycon=uart,mmio32,0x01c28000 mac_addr=36:c9:e3:f1:b8:05 root=/dev/mmcblk0p2 ro rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1969892k/1969892k available, 110876k reserved
[    0.000000] Virtual kernel memory layout:
   vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
   vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
   modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
   memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
     .init : 0xffffffc00096c000 - 0xffffffc0009e5980   (   487 kB)
     .text : 0xffffffc000080000 - 0xffffffc00096ba24   (  9135 kB)
     .data : 0xffffffc0009e6000 - 0xffffffc000b3c8b8   (  1371 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    7.237935] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    7.237966] pid_max: default: 32768 minimum: 301
[    7.238072] Security Framework initialized
[    7.238106] AppArmor: AppArmor initialized
[    7.238150] Mount-cache hash table entries: 256
[    7.248647] Initializing cgroup subsys memory
[    7.248707] Initializing cgroup subsys devices
[    7.248724] Initializing cgroup subsys freezer
[    7.248740] Initializing cgroup subsys blkio
[    7.248755] Initializing cgroup subsys perf_event
[    7.248775] Initializing cgroup subsys hugetlb
[    7.248844] ftrace: allocating 26058 entries in 102 pages
[    7.279282] CPU0: update cpu_power 1968128
[    7.279316] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[    7.280251] virtual base = 0xffffff800000a000.
[    7.280270] gicd_base = 0xffffff800000c000.
[    7.280283] gicc_base = 0xffffff800000e000.
[    7.280869] CPU1: Booted secondary processor
[    7.280892] CPU1: update cpu_power 1968128
[    7.283494] CPU2: Booted secondary processor
[    7.283506] CPU2: update cpu_power 1968128
[    7.287615] CPU3: Booted secondary processor
[    7.287626] CPU3: update cpu_power 1968128
[    7.287705] Brought up 4 CPUs
[    7.287781] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    7.288299] devtmpfs: initialized
[    7.293194] atomic64 test passed
[    7.293215] pinctrl core: initialized pinctrl subsystem
[    7.296203] NET: Registered protocol family 16
[    7.296521] script_sysfs_init success
[    7.297375] dump_class_init,806, success
[    7.298037] vdso: 2 pages (1 code, 1 data) at base ffffffc0009ed000
[    7.298070] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    7.299378] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[    7.300297] DMA: preallocated 256 KiB pool for atomic allocations
[    7.300479] Serial: AMBA PL011 UART driver
[    7.300859] axp81x_board_init: axp regl_devs num = 23
[    7.301079] pll_audio-set_default_rate=24576000 success!
[    7.301111] pll_video0-set_default_rate=297000000 success!
[    7.301189] pll_video1-set_default_rate=297000000 success!
[    7.301257] pll_de-set_default_rate=297000000 success!
[    7.301984] de-set_default_source=pll_de success!
[    7.302000] de-set_default_rate=297000000 success!
[    7.302053] tcon0-set_default_source=pll_mipi success!
[    7.302095] tcon1-set_default_source=pll_video0 success!
[    7.302330] hdmi-set_default_source=pll_video0 success!
[    7.304836] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    7.305090] [sun50iw1p1_pinctrl_probe][838]
[    7.306815] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    7.308110] sunxi hwspinlock vbase:0xffffff800005c000
[    7.318038] sunxi_chipid_probe,150: soc bin:0
[    7.335362] bio: create slab <bio-0> at 0
[    7.335788] pwm module init!
[    7.338116] SCSI subsystem initialized
[    7.338586] usbcore: registered new interface driver usbfs
[    7.338720] usbcore: registered new interface driver hub
[    7.338857] usbcore: registered new device driver usb
[    7.340158] Linux video capture interface: v2.00
[    7.341090] [ARISC] :sunxi-arisc driver v1.10
[    7.352671] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[    7.353080] Advanced Linux Sound Architecture Driver Initialized.
[    7.353667] NetLabel: Initializing
[    7.353681] NetLabel:  domain hash size = 128
[    7.353694] NetLabel:  protocols = UNLABELED CIPSOv4
[    7.353752] NetLabel:  unlabeled traffic allowed by default
[    7.354005] [pm]aw_pm_init!
[    7.354089] rtc physical base = 0x0000000001f00000 .
[    7.354134] np name = /soc@01c00000/rtc@01f00000.
[    7.354149] base = ffffff8000070100, len = 4.
[    7.354163] pmu name: pmu0 .
[    7.354206] pmu0_enable = 0x1.
[    7.354219] pmux_id = 0x6.
[    7.354231] pmux_twi_id = 0x1.
[    7.354242] pmux_twi_addr = 0x34.
[    7.354253] pmu name: pmu1 .
[    7.354311] Warning: can not find np for pmu1.
[    7.354548] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[    7.354713] after inited: sys_mask config = 0x4a55.
[    7.354745] Warning: can not find np for dynamic_standby_para.
[    7.354873] [pm]valid
[    7.354883] [pm]valid
[    7.354892] Notice: sun9i&sun8iw5&sun50i not need support normal standby,                            change to super standby.
[    7.355102] Switching to clocksource arch_sys_counter
[    7.365746] AppArmor: AppArmor Filesystem Enabled
[    7.378196] NET: Registered protocol family 2
[    7.378880] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[    7.379139] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    7.379443] TCP: Hash tables configured (established 16384 bind 16384)
[    7.379530] TCP: reno registered
[    7.379548] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    7.379609] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    7.379849] NET: Registered protocol family 1
[    7.380140] RPC: Registered named UNIX socket transport module.
[    7.380157] RPC: Registered udp transport module.
[    7.380170] RPC: Registered tcp transport module.
[    7.380184] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.380355] Unpacking initramfs...
[    7.423873] Freeing initrd memory: 1048K (ffffffc075dad000 - ffffffc075eb3000)
[    7.425089] kvm [1]: interrupt-controller@1c84000 IRQ25
[    7.425438] kvm [1]: timer IRQ27
[    7.425457] kvm [1]: Hyp mode initialized successfully
[    7.426833] lock super standby defaultly!
[    7.426862] lookup_scene_lock_name: new scene lock super_standby
[    7.426878] scene_lock_init name=super_standby
[    7.426893] scene_lock: super_standby, type 5, count 1
[    7.427552] audit: initializing netlink socket (disabled)
[    7.427601] type=2000 audit(0.180:1): initialized
[    7.428565] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    7.429023] VFS: Disk quotas dquot_6.5.2
[    7.429150] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    7.429561] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    7.429945] NFS: Registering the id_resolver key type
[    7.429995] Key type id_resolver registered
[    7.430009] Key type id_legacy registered
[    7.430028] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    7.430185] NTFS driver 2.1.30 [Flags: R/W].
[    7.430449] fuse init (API version 7.22)
[    7.430845] msgmni has been set to 3977
[    7.431642] io scheduler noop registered
[    7.431660] io scheduler deadline registered
[    7.431704] io scheduler cfq registered (default)
[    7.432523] [DISP]disp_module_init
[    7.433067] [DISP] boot_disp:0x40a
[    7.433646] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[    7.433805] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[    7.433990] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[    7.435083] [DISP] fb_base:0x47400000
[    7.442667] [DISP] Fb_map_kernel_logo,line:880:this is not a bmp picture.
[    7.472553] Console: switching to colour frame buffer device 240x67
[    7.501481] [DISP]disp_module_init finish
[    7.502010] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    7.502164] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[    8.462880] console [ttyS0] enabled
[    8.467358] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    8.474402] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    8.481516] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[    8.488604] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[    8.495818] misc dump reg init
[    8.499576] [drm] Initialized drm 1.1.0 20060810
[    8.508213] loop: module loaded
[    8.511994] sunxi-bt bt.27: Missing bt_power.
[    8.516884] sunxi-bt bt.27: bt_power_name ((null))
[    8.522244] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[    8.528513] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[    8.537313] sunxi-bt bt.27: clk not config
[    8.542025] sunxi-bt bt.27: block state already is 1
[    8.547884] sunxi-wlan wlan.26: wlan_busnum (1)
[    8.552949] sunxi-wlan wlan.26: Missing wlan_power.
[    8.558405] sunxi-wlan wlan.26: wlan_power_name ((null))
[    8.564342] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[    8.570990] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[    8.580557] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[    8.590408] sunxi-wlan wlan.26: clk not config
[    8.596036] tun: Universal TUN/TAP device driver, 1.6
[    8.601684] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    8.609312] WARNING: Get ephy clock is failed
[    8.614851] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.622285] get ehci0-controller drv_vbus_gpio is fail
[    8.628039] get ehci0-controller, regulator_io is no nocare
[    8.634321] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000be6730, 0x:ffffff80000ae000, irq_no:68
[    8.647888] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.658020] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[    8.667949] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0004c619c
[    8.693401] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[    8.701185] ehci_irq: highspeed device connect
[    8.706733] hub 1-0:1.0: USB hub found
[    8.716965] hub 1-0:1.0: 1 port detected
[    8.727414] scene_lock_init name=ehci_standby
[    8.738271] get ehci1-controller drv_vbus_gpio is fail
[    8.749876] get ehci1-controller, regulator_io is no nocare
[    8.761967] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000be6980, 0x:ffffff80000b6000, irq_no:6a
[    8.781493] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.797769] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[    8.813807] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc0004c619c
[    8.841006] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[    8.854918] ehci_irq: highspeed device connect
[    8.866622] hub 2-0:1.0: USB hub found
[    8.877038] hub 2-0:1.0: 1 port detected
[    8.887760] scene_lock_init name=ehci_standby
[    8.899122] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    8.912465] get ohci0-controller drv_vbus_gpio is fail
[    8.924561] get ohci0-controller, regulator_io is no nocare
[    8.937113] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000be6290
[    8.953844] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    8.969908] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[    8.985858] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x61ff726b6b64622c
[    9.037811] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[    9.061962] hub 3-0:1.0: USB hub found
[    9.072417] hub 3-0:1.0: 1 port detected
[    9.083130] scene_lock_init name=ohci_standby
[    9.094230] get ohci1-controller drv_vbus_gpio is fail
[    9.106081] get ohci1-controller, regulator_io is no nocare
[    9.118438] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000be64e0
[    9.134979] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    9.150851] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[    9.166639] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x61ff726b6b64622c
[    9.238984] hub 4-0:1.0: USB hub found
[    9.249548] hub 4-0:1.0: 1 port detected
[    9.260375] scene_lock_init name=ohci_standby
[    9.272041] usbcore: registered new interface driver usb-storage
[    9.285180] usbcore: registered new interface driver ums-alauda
[    9.298161] usbcore: registered new interface driver ums-cypress
[    9.311194] usbcore: registered new interface driver ums-datafab
[    9.324143] usb 2-1: new high-speed USB device number 2 using sunxi-ehci
[    9.337989] usbcore: registered new interface driver ums_eneub6250
[    9.351262] usbcore: registered new interface driver ums-freecom
[    9.364291] usbcore: registered new interface driver ums-isd200
[    9.377162] usbcore: registered new interface driver ums-jumpshot
[    9.390176] usbcore: registered new interface driver ums-karma
[    9.402904] usbcore: registered new interface driver ums-onetouch
[    9.415892] usbcore: registered new interface driver ums-realtek
[    9.428723] usbcore: registered new interface driver ums-sddr09
[    9.441372] usbcore: registered new interface driver ums-sddr55
[    9.453917] usbcore: registered new interface driver ums-usbat
[    9.466419] usbcore: registered new interface driver usbserial
[    9.478720] usbcore: registered new interface driver usbserial_generic
[    9.491738] usbserial: USB Serial support registered for generic
[    9.504537] mousedev: PS/2 mouse device common for all mice
[    9.517052] input: sunxi-keyboard as /devices/virtual/input/input0
[    9.530360] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[    9.543687] sunxi-rtc 1f00000.rtc: RTC enabled
[    9.554316] hub 2-1:1.0: USB hub found
[    9.563972] i2c /dev entries driver
[    9.573223] hub 2-1:1.0: 4 ports detected
[    9.619156] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[    9.641587] sunxi budget cooling probe start !
[    9.652108] CPU freq cooling register Success
[    9.662452] CPU hotplug cooling register Success
[    9.673256] CPU budget cooling register Success
[    9.684256] sunxi gpu cooling probe start !
[    9.694448] CPU gpu cooling register Success
[    9.707699] cpuidle: using governor ladder
[    9.716964] cpuidle: using governor menu
[    9.726657] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in May  7 2016 at 12:34:27
[    9.744326] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[    9.755757] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[    9.767253] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[    9.779006] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[    9.789837] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[    9.801198] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[    9.811652] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    9.827412] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[    9.854519] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    9.884058] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000ca000 irq:92
[    9.896028] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in May  7 2016 at 12:34:27
[    9.913738] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[    9.925514] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[    9.937354] usb 2-1.4: new full-speed USB device number 3 using sunxi-ehci
[    9.949647] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[    9.961467] get() with no identifier
[    9.970167] get() with no identifier
[    9.978806] get() with no identifier
[    9.987380] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[    9.998827] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.009681] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.020919] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.020964] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.020967] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.060086] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.061160] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.063290] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.064098] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.064905] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.065711] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.066332] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.066372] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.068739] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.086163] mmc0: SD Status: Invalid Allocation Unit size.
[   10.087832] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.089641] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.089681] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.089778] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.089797] mmc0: new high speed SDXC card at address 0007
[   10.270095] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.282830] mmcblk0: mmc0:0007 SD64G 58.2 GiB
[   10.294263]  mmcblk0: p1 p2
[   10.297327] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.317019] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000d2000 irq:93
[   10.333376] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.346389] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.358475] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.375778] input: Logitech USB Receiver as /devices/soc.0/1c1b000.ehci1-controller/usb2/2-1/2-1.4/2-1.4:1.0/input/input2
[   10.393627] hid-generic 0003:046D:C52B.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-sunxi-ehci-1.4/input0
[   10.394355] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.429142] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.442323] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.455393] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.467977] input: Logitech USB Receiver as /devices/soc.0/1c1b000.ehci1-controller/usb2/2-1/2-1.4/2-1.4:1.1/input/input3
[   10.485720] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.498521] hid-generic 0003:046D:C52B.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-sunxi-ehci-1.4/input1
[   10.516792] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.530181] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.543650] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.557072] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.569692] hid-generic 0003:046D:C52B.0003: device has no listeners, quitting
[   10.583467] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.595968] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.596127] usbcore: registered new interface driver usbhid
[   10.596129] usbhid: USB HID core driver
[   10.636447] usbcore: registered new interface driver snd-usb-audio
[   10.649326] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.662042] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.679611] sndhdmi sound.7:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.693662] TCP: cubic registered
[   10.703472] NET: Registered protocol family 10
[   10.714932] sit: IPv6 over IPv4 tunneling driver
[   10.726523] NET: Registered protocol family 17
[   10.737350] Key type dns_resolver registered
[   10.748094] Registering SWP/SWPB emulation handler
[   10.759699] registered taskstats version 1
[   10.770422] [DISP] boot_disp:0x40a
[   10.780686] [HDMI] power vcc-hdmi-33
[   10.790874] [HDMI] cec support = 0
[   11.305332] [DISP] disp_device_attached,line:94:attched ok, mgr0<-->device1, type=4
[   11.319797] sunxi-rtc 1f00000.rtc: setting system clock to 2016-07-04 21:00:13 UTC (1467666013)
[   11.330545] [ehci0-controller]: sunxi_usb_disable_ehci
[   11.330550] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000be6730
[   11.330563] scene_lock_destroy name=ehci_standby
[   11.330569] sunxi-ehci 1c1a000.ehci0-controller: remove, state 1
[   11.330586] usb usb1: USB disconnect, device number 1
[   11.330590] usb 1-1: USB disconnect, device number 2
[   11.411487] input: sunxi-ths as /devices/virtual/input/input4
[   11.412093] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   11.412119] [ohci0-controller]: sunxi_usb_disable_ohci
[   11.412123] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000be6290
[   11.412126] scene_lock_destroy name=ohci_standby
[   11.412131] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   11.412144] usb usb3: USB disconnect, device number 1
[   11.415052] ohci_irq: fullspeed or lowspeed device connect
[   11.515222] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   11.515262] thermal thermal_zone0: failed to read out thermal zone 0
[   11.542417] [ehci0-controller]: sunxi_usb_enable_ehci
[   11.542468] ALSA device list:
[   11.542470]   #0: sndhdmi
[   11.573175] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000be6730, 0x:ffffff80000ae000, irq_no:68
[   11.586693] Freeing unused kernel memory: 484K (ffffffc00096c000 - ffffffc0009e5000)
[   11.605977] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[   11.606857] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[   11.642359] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   11.659158] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   11.675619] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0006c1ecc
[   11.700472] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   11.704449] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   11.704454] ehci_irq: highspeed device connect
[   11.705087] hub 1-0:1.0: USB hub found
[   11.705100] hub 1-0:1.0: 1 port detected
[   11.705235] scene_lock_init name=ehci_standby
[   11.705238] [ohci0-controller]: sunxi_usb_enable_ohci
[   11.705243] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000be6290
[   11.705285] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   11.705299] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   11.705333] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0006c1ecc
[   11.767860] hub 3-0:1.0: USB hub found
[   11.767875] hub 3-0:1.0: 1 port detected
[   11.767982] scene_lock_init name=ohci_standby
[   12.019361] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[   12.126907] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[   12.148404] systemd[1]: Detected architecture 'arm64'.
[   12.207728] systemd[1]: Set hostname to <pine64pro>.
[   12.509115] systemd[1]: Expecting device dev-ttyS0.device...
[   12.540973] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[   12.555922] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.570618] systemd[1]: Starting Remote File Systems (Pre).
[   12.599937] systemd[1]: Reached target Remote File Systems (Pre).
[   12.612921] systemd[1]: Starting Encrypted Volumes.
[   12.639277] systemd[1]: Reached target Encrypted Volumes.
[   12.651441] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[   12.666614] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   12.681624] systemd[1]: Starting Paths.
[   12.708160] systemd[1]: Reached target Paths.
[   12.719272] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.735999] systemd[1]: Starting Swap.
[   12.767202] systemd[1]: Reached target Swap.
[   12.778309] systemd[1]: Expecting device dev-mmcblk0p1.device...
[   12.806564] systemd[1]: Starting Root Slice.
[   12.836083] systemd[1]: Created slice Root Slice.
[   12.847564] systemd[1]: Starting User and Session Slice.
[   12.875444] systemd[1]: Created slice User and Session Slice.
[   12.887940] systemd[1]: Starting Delayed Shutdown Socket.
[   12.914814] systemd[1]: Listening on Delayed Shutdown Socket.
[   12.927218] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[   12.964012] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   12.977795] systemd[1]: Starting Journal Socket (/dev/log).
[   13.013203] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.025833] systemd[1]: Starting udev Control Socket.
[   13.052567] systemd[1]: Listening on udev Control Socket.
[   13.064474] systemd[1]: Starting udev Kernel Socket.
[   13.091924] systemd[1]: Listening on udev Kernel Socket.
[   13.103653] systemd[1]: Starting Journal Socket.
[   13.131285] systemd[1]: Listening on Journal Socket.
[   13.142670] systemd[1]: Starting System Slice.
[   13.170673] systemd[1]: Created slice System Slice.
[   13.181816] systemd[1]: Started File System Check on Root Device.
[   13.194206] systemd[1]: Starting system-systemd\x2dfsck.slice.
[   13.229695] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   13.242342] systemd[1]: Starting system-getty.slice.
[   13.269051] systemd[1]: Created slice system-getty.slice.
[   13.280460] systemd[1]: Starting system-serial\x2dgetty.slice.
[   13.308404] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   13.320871] systemd[1]: Starting Increase datagram queue length...
[   13.349366] systemd[1]: Starting Restore / save the current clock...
[   13.384826] systemd[1]: Starting Initialize Sunxi disp2 HDMI output mode...
[   13.418785] systemd[1]: Mounting Huge Pages File System...
[   13.465589] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   13.556060] systemd[1]: Started Set Up Additional Binary Formats.
[   13.575412] hdmi_clk_disable_prepare()L176
[   13.589312] systemd[1]: Starting Load Kernel Modules...
[   13.624869] systemd[1]: Mounting POSIX Message Queue File System...
[   13.654307] systemd[1]: Starting udev Coldplug all Devices...
[   13.684191] systemd[1]: Mounting Debug File System...
[   13.713665] systemd[1]: Starting Slices.
[   13.741448] systemd[1]: Reached target Slices.
[   13.771022] systemd[1]: Mounted Debug File System.
[   13.800533] systemd[1]: Mounted POSIX Message Queue File System.
[   13.812466] hdmi_clk_enable_prepare()L161
[   13.839855] systemd[1]: Mounted Huge Pages File System.
[   13.918579] systemd[1]: Started Increase datagram queue length.
[   13.948107] systemd[1]: Started Restore / save the current clock.
[   13.977616] systemd[1]: Started Initialize Sunxi disp2 HDMI output mode.
[   14.007149] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   14.064568] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.098055] systemd[1]: Starting Syslog Socket.
[   14.109633] cfg80211: Calling CRDA to update world regulatory domain
[   14.125222] systemd[1]: Listening on Syslog Socket.
[   14.134248] systemd[1]: Starting Journal Service...
[   14.175507] systemd[1]: Started Journal Service.
[   14.314292] RTL871X: module init start
[   14.321956] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   14.332955] RTL871X: build time: May  7 2016 12:47:20
[   14.341979] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   14.353095] sunxi-wlan wlan.26: bus_index: 1
[   14.361474] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   14.410494] systemd-udevd[1485]: starting version 215
[   14.480806] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   14.481009] RTL871X: module init ret=0
[   14.505732] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   14.528567] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   14.558886] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   14.570336] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   14.580962] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   14.598874] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   14.618279] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   14.631426] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   14.643088] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   14.654308] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   14.665578] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   14.676832] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   14.688075] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   14.699221] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   14.712035] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   14.722756] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   14.738522] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   14.748659] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   15.118518] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   15.358548] sunxi_ss_alg_register()681 - crypto_register_ahash(md5) failed! return -22
[   15.371192] sunxi_ss_probe()793 - sunxi_ss_alg_register() failed! return -22
[   15.382850] ss: probe of 1c15000.ce failed with error -22
[   15.437991] sunxi cedar version 0.1
[   15.445893] [cedar]: install start!!!
[   15.453679] ycy the get irq is 90
[   15.463350] ycy clk_bass_vir 0x18  is ffffff8001564018, the value:3006207
[   15.474715] ycy clk_bass_vir 0x13c  is ffffff800156413c, the value:0
[   15.485499] ycy clk_bass_vir 0x64  is ffffff8001564064, the value:601810
[   15.505901] ycy clk_bass_vir 0x2c4  is ffffff80015642c4, the value:601c10
[   15.518528] ycy clk_bass_vir 0x100  is ffffff8001564100, the value:0
[   15.522384] sunxi-bt bt.27: block state already is 1
[   15.538769] [cedar]: install end!!!
[   15.784372] Mali: Set gpu frequency to 408 MHz
[   15.793175] Mali: Init Mali gpu clocks successfully
[   15.803063] gpu cooling callback register Success
[   15.814036] Mali: Mali device driver loaded
[   16.032763] cfg80211: World regulatory domain updated:
[   16.042014] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   16.054970] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.066735] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.078398] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   16.090071] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   16.101932] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   16.113476] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   16.125463] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   16.136899] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   16.261125] [VFE]cci probe end cci_sel = 0!
[   16.272999] [VFE]cci_init end
[   16.450997] [VFE]Welcome to Video Front End driver
[   16.459665] [VFE]csi probe end csi_sel = 0!
[   16.467798] [VFE]csi_init end
[   16.474668] [VFE]isp probe start isp_sel = 0!
[   16.483360] [ISP] isp platform_id = 3!
[   16.490629] [VFE]isp probe end isp_sel = 0!
[   16.498919] [VFE]sunxi_isp_platform_register end
[   16.508358] [VFE]mipi probe start mipi_sel = 0!
[   16.516694] [VFE]mipi probe end mipi_sel = 0!
[   16.525013] [VFE]mipi_init end
[   16.531671] [VFE]flash_init end
[   16.539789] [VFE]pdev->id = 0
[   16.546252] [VFE]dev->vip_sel = 0
[   16.553074] [VFE_WARN]fetch csi0_dev0_twi_id from device_tree failed
[   16.563284] [VFE_WARN]fetch csi0_dev0_afvdd from device_tree failed
[   16.573271] [VFE_WARN]fetch csi0_dev0_afvdd_vol from device_tree failed
[   16.583619] [VFE_WARN]fetch csi0_dev0_power_en from device_tree failed
[   16.593840] [VFE_WARN]fetch csi0_dev0_flash_en from device_tree failed
[   16.603921] [VFE_WARN]fetch csi0_dev0_flash_mode from device_tree failed
[   16.614194] [VFE_WARN]fetch csi0_dev0_af_pwdn from device_tree failed
[   16.624098] [VFE_WARN]fetch csi0_dev1_twi_id from device_tree failed
[   16.634034] [VFE_WARN]fetch csi0_dev1_afvdd from device_tree failed
[   16.643763] [VFE_WARN]fetch csi0_dev1_afvdd_vol from device_tree failed
[   16.653838] [VFE_WARN]fetch csi0_dev1_power_en from device_tree failed
[   16.663906] [VFE_WARN]fetch csi0_dev1_flash_en from device_tree failed
[   16.673889] [VFE_WARN]fetch csi0_dev1_flash_mode from device_tree failed
[   16.685322] [VFE_WARN]fetch csi0_dev1_af_pwdn from device_tree failed
[   16.695212] [VFE]fetch rear sensor list info start!
[   16.703276] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg.ini"
[   16.749932] [vfe_warn]open file failed!
[   16.794732] [VFE]fetch rear sensor list info end!
[   16.802801] [VFE]fetch front sensor list info start!
[   16.811011] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg.ini"
[   16.857613] [vfe_warn]open file failed!
[   16.902774] [VFE]fetch front sensor list info end!
[   16.911115] [VFE_WARN]os_gpio_request failed, gpio=129, ret=0xfffffff0, -16
[   16.922134] [VFE]vfe_init end
[   16.929511] [VFE]probe_work_handle start!
[   16.937358] [VFE]vfe_runtime_resume
[   16.956777] [VFE]..........................vfe clk open!.......................
[   16.967970] [VFE_WARN]vfe dphy clock is null
[   16.975773] [VFE]v4l2 subdev register input_num = 0
[   16.984937] [VFE]vfe sensor detect start! input_num = 0
[   16.993721] [VFE_WARN]NOT found this item:  hm5065, you can add this sensor in the sensor_list_t!
[   17.006722] [VFE]Sub device register "hm5065" i2c_addr = 0x3e start!
[   17.016959] [VFE_ERR]Error registering v4l2 subdevice No such device!
[   17.028310] [VFE_ERR]vfe sensor register check error at input_num = 0
[   17.038646] [VFE]v4l2 subdev register input_num = 1
[   17.047296] axp81x_aldo1: Failed to create debugfs directory
[   17.056816] axp81x_dldo3: Failed to create debugfs directory
[   17.067097] axp81x_eldo3: Failed to create debugfs directory
[   17.076522] axp81x_aldo1: Failed to create debugfs directory
[   17.085952] [VFE]vfe sensor detect start! input_num = 1
[   17.091405] systemd-journald[1482]: Received request to flush runtime journal from PID 1
[   17.107183] [VFE_WARN]NOT found this item:  gc2145, you can add this sensor in the sensor_list_t!
[   17.120379] [VFE]Sub device register "gc2145" i2c_addr = 0x78 start!
[   17.131678] [VFE_ERR]Error registering v4l2 subdevice No such device!
[   17.142318] [VFE_ERR]vfe sensor register check error at input_num = 1
[   17.153008] [VFE]V4L2 device registered as (null)
[   17.161868] [VFE]vfe_runtime_suspend
[   17.169409] [VFE]..........................vfe clk close!.......................
[   17.181625] [VFE]probe_work_handle end!
[   17.411672] gpu cooling callback set freq limit 0
[   18.166362] rtl8192cu: Chip version 0x10
[   18.267700] rtl8192cu: MAC address: 80:3f:5d:f3:44:01
[   18.277013] rtl8192cu: Board Type 0
[   18.285039] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[   18.295218] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[   18.306437] usbcore: registered new interface driver rtl8192cu
[   18.319952] rtlwifi: Loading alternative firmware rtlwifi/rtl8192cufw.bin
[   18.332110] rtlwifi: Firmware rtlwifi/rtl8192cufw_TMSC.bin not available
[   18.944513] libphy: 1c30000.eth: probed
[   18.952837] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00)
[   23.866851] libphy: 1c30000.eth-0:00 - Link is Up - 1000/Full
[   44.380582] [DISP] disp_ioctl,line:1558:para err in disp_ioctl, cmd = 0x0,screen id = 65536
  Q4OS WiFi Dongle not working cheezmeister 3 4,798 04-07-2017, 08:01 AM
Last Post: iccoldbeer
  Wifi connect through terminal? cheezmeister 0 2,072 04-02-2017, 09:44 AM
Last Post: cheezmeister
  How to connect with wifi ? yirmidokuz 27 37,588 05-28-2016, 07:46 AM
Last Post: jl_678
