Q4OS add storage drive
Big Grin
I'm by no means a master at Linux so this application is fantastic for me.   Smile
I'm trying to figure out how to use the 128gig thumbdrive as a system storage drive to load and save files to. I'd like to make it the download path for Firefox. Just not sure how to mount and direct the OS to it. Any info would be greatly appreciated. This will defiantly help me to learn Linux a little easier. Thanks again!
whats the usb drives format ?  The drive should show up in your file manager (not sure what Q4OS uses - Doplhin?) when you plug it in. If it doesn't, open terminal and type: sudo fdisk -l
Paste what it prints out here.
As for firefox, once you get your drive set up, you can just go to preferences in firefox -> general -> save files to
and select the mounted drive or a folder within.
  eMMC module as storage for Debian/Android le_moose1 1 3,950 03-25-2018, 08:11 PM
Last Post: KNERD
  Q4OS WiFi Dongle not working cheezmeister 3 4,818 04-07-2017, 08:01 AM
Last Post: iccoldbeer
  Expanding my SD drive from 7.5G ->64G m16bishop 2 3,906 08-04-2016, 01:03 PM
Last Post: m16bishop
